Re: Vacuum hold-down for 3D build surface. January 24, 2017 06:38AM |
Re: Vacuum hold-down for 3D build surface. January 24, 2017 07:15AM |
Re: Vacuum hold-down for 3D build surface. January 24, 2017 07:16AM |
Re: Vacuum hold-down for 3D build surface. January 24, 2017 07:21AM |
leadinglights
I have put a YouTube video showing the first successful print on the Vacuum Hold_Down stage [www.youtube.com]
I have edited the video as I had not set up Repetier to keep on the bed and hot-end heat but the time taken for a change over should be about right
Mike
Re: Vacuum hold-down for 3D build surface. January 24, 2017 07:23AM |
Re: Vacuum hold-down for 3D build surface. January 24, 2017 10:11AM |
Re: Vacuum hold-down for 3D build surface. January 24, 2017 10:31AM |
Re: Vacuum hold-down for 3D build surface. January 26, 2017 02:57PM |
Re: Vacuum hold-down for 3D build surface. September 24, 2019 12:58PM |
Re: Vacuum hold-down for 3D build surface. September 24, 2019 09:49PM |
Re: Vacuum hold-down for 3D build surface. September 28, 2019 05:13PM |
Bill Clark
.................................................................................. a similar design for a new machine I am building and had determined for abs, in a heated chamber, at least 750 mb of vacuum would be needed producing .77 kg/cm2 of holding force. PLA should need less (dah)
Re: Vacuum hold-down for 3D build surface. July 29, 2021 08:14AM |
Re: Vacuum hold-down for 3D build surface. September 02, 2021 09:43AM |
Re: Vacuum hold-down for 3D build surface. September 02, 2021 12:59PM |
