Extruder feed problem (SOLVED) February 05, 2011 06:01PM |
Re: Extruder feed problem February 05, 2011 06:31PM |
Re: Extruder feed problem February 05, 2011 06:40PM |
Re: Extruder feed problem February 05, 2011 08:56PM |
Re: Extruder feed problem February 05, 2011 11:47PM |
Re: Extruder feed problem February 06, 2011 04:43AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Extruder feed problem February 06, 2011 06:19AM |
Re: Extruder feed problem February 06, 2011 07:46AM |
Re: Extruder feed problem February 06, 2011 11:51AM |
Re: Extruder feed problem February 06, 2011 12:24PM |
Re: Extruder feed problem February 06, 2011 12:30PM |
Re: Extruder feed problem February 06, 2011 01:08PM |
Re: Extruder feed problem February 07, 2011 06:16PM |
) Brass interface.|
Re: Extruder feed problem February 07, 2011 08:37PM |
The only time that the filament got stuck on me was when I tried to remove the filament by retracting it while the extruder was hot. It got to a point where it stopped retracting. I found that at that point, I couldn't go forward either. After taking the cold end apart (Adrian's geared extruder), I found that there was a bulge between the filament drive and the hole where the filament goes into the hot end.
Re: Extruder feed problem February 08, 2011 04:48AM |
Re: Extruder feed problem February 08, 2011 04:49AM |
Re: Extruder feed problem May 23, 2011 06:56AM |
Re: Extruder feed problem May 23, 2011 06:58AM |
Re: Extruder feed problem May 23, 2011 07:11AM |
Re: Extruder feed problem May 23, 2011 08:36AM |
Oxidised PLA is harder / has a higher melt temperature? Have you a good method of clearing it when necessary?
Re: Extruder feed problem May 23, 2011 02:40PM |
Re: Extruder feed problem (SOLVED) May 24, 2011 02:16AM |
Re: Extruder feed problem (SOLVED) May 24, 2011 05:34PM |
