Need Recommendation for Source of 400mm x 400mm Borosilicate Glass December 27, 2016 11:10AM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass December 27, 2016 04:16PM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass December 27, 2016 06:49PM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass December 28, 2016 01:51AM |
Origamib
Your local glazier will likely be able to do toughened or borosilicate,which will probably be cheaper than glass + spreader (and lighter).
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass December 28, 2016 07:21AM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass December 28, 2016 02:56PM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass December 28, 2016 04:42PM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass January 06, 2017 05:22AM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass January 06, 2017 07:08AM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass January 06, 2017 09:08AM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass January 06, 2017 04:31PM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass January 07, 2017 04:09AM |
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass January 07, 2017 12:06PM |
DjDemonD
I cannot see what advantage any glass brings if you have a sheet of aluminium flat enough, thick enough, cast and machined. Glass is potentially expensive, fragile, not as flat as you expect it to be and an insulator, not much to recommend it really.
Re: Need Recommendation for Source of 400mm x 400mm Borosilicate Glass December 01, 2017 09:45AM |
