Printed P-38 December 30, 2016 12:29AM |
Re: Printed P-38 December 30, 2016 11:47AM |
Re: Printed P-38 December 30, 2016 12:45PM |
Re: Printed P-38 December 30, 2016 10:06PM |
Re: Printed P-38 December 31, 2016 06:42PM |
Re: Printed P-38 December 31, 2016 06:49PM |
Re: Printed P-38 December 31, 2016 07:00PM |
Re: Printed P-38 December 31, 2016 09:01PM |
Re: Printed P-38 January 01, 2017 08:14AM |
Re: Printed P-38 January 01, 2017 09:23AM |
tody79
The canard layout with a pusher has some advantages and disadvantages. It will work as good as a conventional layout when build as a model aircraft. A turbine is not beneficial unless you fly fast. At low speed, the prop is more efficient.
It would be a nice model aircraft.
Re: Printed P-38 January 01, 2017 10:01AM |
Re: Printed P-38 January 01, 2017 10:46AM |
Re: Printed P-38 January 01, 2017 11:12AM |
Re: Printed P-38 January 01, 2017 12:15PM |
Re: Printed P-38 January 01, 2017 12:17PM |
Re: Printed P-38 January 02, 2017 04:24AM |
Re: Printed P-38 January 02, 2017 06:19AM |
Re: Printed P-38 January 02, 2017 07:29AM |
frankvdh
Some of what's posted above is inaccurate, so, FWIW, here's some info (off-topic for the forum, on-topic for the thread) from a pilot and one-time aircraft kit builder, and long time ago model builder and flyer... hope it's of interest:
1. The canards do generate lift.... this makes the canard design a little more efficient that the conventionally designed tailplane, which actual "lifts" downwards. But the main function of the canard or tailplane is to aerodynamically balance the aircraft lengthwise.
2. The COG still needs to be about a 1/3 to 1/4 of the main wing. In pushers, this is done by putting the pilot and passenger forward of the leading edge. Something heavy like the battery will be right in the nose. Some require lead ballast.
3. Fuel tanks on aircraft tend to be in or near the leading edge to minimise COG changes as fuel burns.
4. The Vari-Ezes (as pictured) and such-like didn't have especially light engines... just normal aircraft engines.
5. In a model, I guess placing batteries and heavy stuff at the front (plus ballast if needed) would work... the important thing (I guess) would be to build the tail light.
6. Adding thrust isn't necessarily the answer. Although no pilot ever complained of having too much power.
7. There was a "Rocket Racing League" in the USA in 2010 or so, flying Velocity canards with rocket engines.
8. When scaling down an aircraft to a model, it's necessary to change the airfoil... aerodynamics does not scale well, and airspeeds tend to be lower.
9. There are canard aircraft which have tractor props [www.geeksville.com]
10. There's also the Eagle, which has a canard and a tailplane.
11. The *really* cool Rutan canard is the Berkut
12. Cooling a pusher is more challenging than a tractor, especially at low airspeeds.
Re: Printed P-38 January 02, 2017 10:02AM |
