Yeah I Dont Have The Original Firmware The One I Posted Is Only The Config For The Melzi Board If I Try To Compile It In The New Arduino IDE I Get Lots Of Errors
Ive Managed To Change Steps Of X And Y To 80 Using Repitier Host And Saving Eprom Settings
Ive Tighened The Y Belt Just In Case But Still The Same
There Is Something Changing The Size Not Sure What Its To Do With But The Printer Prints Great
I Dont Think Its To Do With The Max Enstops Cause It Printed Fine Till This Error Appeared
Not Sure If Its Slicing Problem Or Setting In The Printer Firmware Or Software But tried Slicing And Printing From SD Card And Still The Same
Heres Log Of Print From Repitier Host
19:53:17.341 : OpenGL version:2.1.0 - Build 8.15.10.2993
19:53:17.342 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_EXT_framebuffer_blit GL_ARB_framebuffer_object GL_EXT_texture_array GL_ARB_map_buffer_range GL_EXT_texture_snorm GL_INTEL_performance_queries GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_draw_elements_base_vertex GL_EXT_gpu_program_parameters GL_ARB_compatibility GL_ARB_vertex_array_object
19:53:17.342 : OpenGL renderer
HDGD Quantic C3
19:53:17.342 : Using fast VBOs for rendering is possible
19:53:24.007 : Printer reset detected - initalizing
19:53:24.009 : start
19:53:24.009 : echo: External Reset
19:53:24.009 : Marlin1.0.2
19:53:24.011 : echo: Last Updated: Sep 13 201514.02.15 00:42:35 | Author: Bakko
19:53:24.011 : Compiled: Sep 13 2015
19:53:24.011 : echo: Free Memory: 3169 PlannerBufferBytes: 1232
19:53:24.016 : echo
tored settings retrieved
19:53:24.016 : echo
teps per unit:
19:53:24.019 : echo: M92 X80.00 Y80.00 Z533.33 E100.00
19:53:24.019 : echo:Maximum feedrates (mm/s):
19:53:24.019 : echo: M203 X500.00 Y500.00 Z5.00 E25.00
19:53:24.024 : echo:Maximum Acceleration (mm/s2):
19:53:24.024 : echo: M201 X9000 Y9000 Z100 E10000
19:53:24.028 : echo:Acceleration: S=acceleration, T=retract acceleration
19:53:24.030 : echo: M204 S3000.00 T3000.00
19:53:24.036 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
19:53:24.036 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
19:53:24.040 : echo:Home offset (mm):
19:53:24.040 : echo: M206 X0.00 Y0.00 Z0.00
19:53:24.040 : echo
ID settings:
19:53:24.043 : echo: M301 P22.20 I1.08 D114.00
19:53:27.808 : echo
D init fail
19:53:27.906 : FIRMWARE_NAME:Marlin V1.0.2; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[
github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE
rusa i3 EXTRUDER_COUNT:1 UUID:73ed22ea-b438-11e4-a71e-12e3f512a338
19:53:27.941 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
19:53:27.941 : echo:Active Extruder: 0
19:53:27.941 : Begin file list
19:53:27.943 : End file list
19:53:27.947 : echo:Active Extruder: 0
19:53:50.037 : echo:endstops hit: Z:0.00
19:55:05.977 : Starting object analyser ...
19:55:05.998 : Object is manifold.
19:55:06.000 : Analysing finished.
19:55:23.832 : CuraEngine command:C:\Program Files\Repetier-Host\plugins\CuraEngine\CuraEngine.exe -p -v -c "C:\Users\Haydn\AppData\Local\RepetierHost\cura.ini" -s posx=0 -s posy=0 -o "C:\Users\Haydn\AppData\Local\RepetierHost\composition.gcode" "C:\Users\Haydn\AppData\Local\RepetierHost\composition0.stl"
19:55:23.880 : Cura_SteamEngine version 15.01
19:55:23.880 : Copyright (C) 2014 David Braam
19:55:23.880 : This program is free software: you can redistribute it and/or modify
19:55:23.880 : it under the terms of the GNU Affero General Public License as published by
19:55:23.880 : the Free Software Foundation, either version 3 of the License, or
19:55:23.880 : (at your option) any later version.
19:55:23.880 : This program is distributed in the hope that it will be useful,
19:55:23.880 : but WITHOUT ANY WARRANTY; without even the implied warranty of
19:55:23.880 : MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
19:55:23.880 : GNU Affero General Public License for more details.
19:55:23.880 : You should have received a copy of the GNU Affero General Public License
19:55:23.880 : along with this program. If not, see [
www.gnu.org].
19:55:23.880 : Default config 'default.cfg' not used
19:55:23.891 : Loading C:\Users\Haydn\AppData\Local\RepetierHost\composition0.stl from disk...
19:55:23.895 : Loaded from disk in 0.000s
19:55:23.895 : Analyzing and optimizing model...
19:55:23.907 : Face counts: 3768 -> 3388 89.9%
19:55:23.907 : Vertex counts: 11304 -> 1694 15.0%
19:55:23.907 : Size: 19.603000 19.601000 28.001000
19:55:23.907 : vMin: 90.198000 90.199000 0.000000
19:55:23.907 : vMax: 109.801000 109.800000 28.001000
19:55:23.907 : Matrix: 1.000000 0.000000 0.000000
19:55:23.907 : Matrix: 0.000000 1.000000 0.000000
19:55:23.907 : Matrix: 0.000000 0.000000 1.000000
19:55:23.907 : Optimize model 0.016s
19:55:23.907 : Slicing model...
19:55:23.908 : Layer count: 140
19:55:23.955 : Sliced model in 0.046s
19:55:23.955 : Generating support map...
19:55:23.955 : Generating layer parts...
19:55:23.985 : Generated layer parts in 0.032s
19:55:24.145 : Generated inset in 0.156s
19:55:24.384 : Generated up/down skin in 0.249s
19:55:25.231 : Wrote layers in 0.84s.
19:55:25.235 : Wrote 963.2 kilobytes.
19:55:25.236 : Total time elapsed 1.34s.
19:55:25.236 : Print time: 1145
19:55:25.236 : Filament: 919
19:55:25.236 : Filament2: 0
19:57:01.186 : Printing layer 1 of 140
19:57:22.206 : Printing layer 2 of 140
19:57:34.278 : Printing layer 3 of 140
19:57:45.897 : Printing layer 4 of 140
19:57:56.842 : Printing layer 5 of 140
19:58:08.692 : Printing layer 6 of 140
19:58:18.126 : Printing layer 7 of 140
19:58:27.194 : Printing layer 8 of 140
19:58:36.124 : Printing layer 9 of 140
19:58:45.373 : Printing layer 10 of 140
19:58:54.585 : Printing layer 11 of 140
19:59:03.965 : Printing layer 12 of 140
19:59:13.362 : Printing layer 13 of 140
19:59:22.841 : Printing layer 14 of 140
19:59:32.401 : Printing layer 15 of 140
19:59:41.781 : Printing layer 16 of 140
19:59:51.255 : Printing layer 17 of 140
20:00:00.668 : Printing layer 18 of 140
20:00:10.224 : Printing layer 19 of 140
20:00:19.609 : Printing layer 20 of 140
20:00:29.021 : Printing layer 21 of 140
20:00:38.504 : Printing layer 22 of 140
20:00:48.060 : Printing layer 23 of 140
20:00:57.482 : Printing layer 24 of 140
20:01:06.988 : Printing layer 25 of 140
20:01:16.791 : Printing layer 26 of 140
20:01:26.360 : Printing layer 27 of 140
20:01:35.211 : Printing layer 28 of 140
20:01:44.850 : Printing layer 29 of 140
20:01:54.901 : Printing layer 30 of 140
20:02:04.257 : Printing layer 31 of 140
20:02:13.440 : Printing layer 32 of 140
20:02:23.148 : Printing layer 33 of 140
20:02:32.561 : Printing layer 34 of 140
20:02:42.117 : Printing layer 35 of 140
20:02:51.485 : Printing layer 36 of 140
20:02:59.399 : Printing layer 37 of 140
20:03:07.439 : Printing layer 38 of 140
20:03:19.450 : Printing layer 39 of 140
20:03:30.886 : Printing layer 40 of 140
20:03:42.625 : Printing layer 41 of 140
20:03:51.997 : Printing layer 42 of 140
20:04:01.328 : Printing layer 43 of 140
20:04:10.803 : Printing layer 44 of 140
20:04:20.339 : Printing layer 45 of 140
20:04:29.739 : Printing layer 46 of 140
20:04:40.246 : Printing layer 47 of 140
20:04:50.589 : Printing layer 48 of 140
20:05:00.551 : Printing layer 49 of 140
20:05:10.659 : Printing layer 50 of 140
20:05:16.997 : Printing layer 51 of 140
20:05:23.091 : Printing layer 52 of 140
20:05:29.432 : Printing layer 53 of 140
20:05:35.315 : Printing layer 54 of 140
20:05:41.024 : Printing layer 55 of 140
20:05:46.828 : Printing layer 56 of 140
20:05:52.621 : Printing layer 57 of 140
20:05:58.601 : Printing layer 58 of 140
20:06:04.631 : Printing layer 59 of 140
20:06:10.480 : Printing layer 60 of 140
20:06:16.329 : Printing layer 61 of 140
20:06:22.179 : Printing layer 62 of 140
20:06:28.028 : Printing layer 63 of 140
20:06:33.877 : Printing layer 64 of 140
20:06:39.722 : Printing layer 65 of 140
20:06:45.567 : Printing layer 66 of 140
20:06:51.818 : Printing layer 67 of 140
20:06:57.602 : Printing layer 68 of 140
20:07:02.570 : Printing layer 69 of 140
20:07:07.768 : Printing layer 70 of 140
20:07:13.015 : Printing layer 71 of 140
20:07:18.210 : Printing layer 72 of 140
20:07:23.436 : Printing layer 73 of 140
20:07:29.621 : Printing layer 74 of 140
20:07:35.794 : Printing layer 75 of 140
20:07:41.602 : Printing layer 76 of 140
20:07:47.476 : Printing layer 77 of 140
20:07:53.285 : Printing layer 78 of 140
20:07:59.080 : Printing layer 79 of 140
20:08:04.893 : Printing layer 80 of 140
20:08:10.685 : Printing layer 81 of 140
20:08:16.538 : Printing layer 82 of 140
20:08:22.387 : Printing layer 83 of 140
20:08:28.282 : Printing layer 84 of 140
20:08:34.090 : Printing layer 85 of 140
20:08:39.939 : Printing layer 86 of 140
20:08:45.789 : Printing layer 87 of 140
20:08:51.638 : Printing layer 88 of 140
20:08:57.544 : Printing layer 89 of 140
20:09:03.341 : Printing layer 90 of 140
20:09:09.190 : Printing layer 91 of 140
20:09:15.039 : Printing layer 92 of 140
20:09:20.848 : Printing layer 93 of 140
20:09:26.640 : Printing layer 94 of 140
20:09:32.492 : Printing layer 95 of 140
20:09:38.342 : Printing layer 96 of 140
20:09:44.191 : Printing layer 97 of 140
20:09:50.040 : Printing layer 98 of 140
20:09:56.206 : Printing layer 99 of 140
20:10:01.985 : Printing layer 100 of 140
20:10:08.236 : Printing layer 101 of 140
20:10:13.151 : Printing layer 102 of 140
20:10:18.390 : Printing layer 103 of 140
20:10:23.670 : Printing layer 104 of 140
20:10:28.790 : Printing layer 105 of 140
20:10:34.197 : Printing layer 106 of 140
20:10:40.542 : Printing layer 107 of 140
20:10:46.355 : Printing layer 108 of 140
20:10:52.548 : Printing layer 109 of 140
20:10:58.307 : Printing layer 110 of 140
20:11:04.112 : Printing layer 111 of 140
20:11:09.920 : Printing layer 112 of 140
20:11:15.715 : Printing layer 113 of 140
20:11:21.565 : Printing layer 114 of 140
20:11:27.414 : Printing layer 115 of 140
20:11:33.263 : Printing layer 116 of 140
20:11:39.113 : Printing layer 117 of 140
20:11:44.966 : Printing layer 118 of 140
20:11:50.774 : Printing layer 119 of 140
20:11:56.563 : Printing layer 120 of 140
20:12:02.411 : Printing layer 121 of 140
20:12:08.260 : Printing layer 122 of 140
20:12:14.110 : Printing layer 123 of 140
20:12:19.959 : Printing layer 124 of 140
20:12:25.808 : Printing layer 125 of 140
20:12:31.658 : Printing layer 126 of 140
20:12:37.507 : Printing layer 127 of 140
20:12:43.356 : Printing layer 128 of 140
20:12:49.206 : Printing layer 129 of 140
20:12:55.055 : Printing layer 130 of 140
20:13:00.904 : Printing layer 131 of 140
20:13:06.754 : Printing layer 132 of 140
20:13:12.603 : Printing layer 133 of 140
20:13:18.448 : Printing layer 134 of 140
20:13:24.703 : Printing layer 135 of 140
20:13:30.491 : Printing layer 136 of 140
20:13:35.418 : Printing layer 137 of 140
20:13:40.744 : Printing layer 138 of 140
20:13:45.851 : Printing layer 139 of 140
20:13:51.111 : Printing layer 140 of 140
20:13:55.210 : Reduced visual quality for better framerates and to protect print quality.
20:13:55.210 : You can disable this in Config->Preferences->Basic Settings->Behaviour.
20:13:56.398 : echo:Active Extruder: 0
20:13:56.399 : Printjob finished at 02/01/2017 20:13
20:13:56.399 : Printing Time: 17m:52s
20:13:56.399 : Lines Send: 32542
Thank You Very Much For Your Help I Am Greatfull
Haydn
