I recently built a Hictop 3DP-11-ATL, upon initial power on every stepper motor will move one direction then reverse for one second and endlessly repeat the process. All the heating elements begin to heat up and the cooling fans pulse in speed in relation to the intervals of the steppers...
The LCD does work and I have full access to the menu. I have tried disconnecting everything but a single motor but still have no luck
The control board is the MPX.3, I can't seem to find the firmware for this machine to attempt to reload it.
Any ideas? Thanks!
Re: Initial Power of Hictop moves all axis one direction for 1 second then reverses in an endless cycle
January 01, 2017 08:27AM
according to this its MKS_BASE comptable
So should be easy to make the standard marlin run on it
Edited 1 time(s). Last edit at 01/01/2017 08:29AM by Dust.
At first sight, it seems to be related to endstops. But without a homing command, the motors shouldn't move at power up.
I ended up finding the firmware for this Hictop on Thingiverse, it now works fine. I'm assuming it had some initial loop test installed on this board for testing but was never flashed with firmware afterwards.
