CF reinforced nylon!! January 02, 2017 08:33PM |
Re: CF reinforced nylon!! January 02, 2017 10:55PM |
Re: CF reinforced nylon!! January 03, 2017 04:06AM |
Re: CF reinforced nylon!! January 03, 2017 06:46AM |
epicepee
Are you familiar with MarkForged Onyx filament? It is a high-quality, high-cost version of this, and I have had excellent experiences with it.
o_lampe
What do you expect from such a material combination?
Re: CF reinforced nylon!! January 04, 2017 03:14AM |
Re: CF reinforced nylon!! January 04, 2017 06:42AM |
o_lampe
Right after I'd sent the above comment about carbon being abrasive, I thought: Graphite is 100% carbon and is used as dry grease. Maybe I was wrong with my statement and the nylon filament just contains a shot of graphite? I hope you can show us some parts later, I'm curious about the surface finish.
Re: CF reinforced nylon!! January 04, 2017 07:42AM |
Re: CF reinforced nylon!! January 04, 2017 08:36AM |
Re: CF reinforced nylon!! January 04, 2017 08:45AM |
o_lampe
Then I'd give CF/ABS a chance and just dip it in aceton for a short moment. That would improve layer bonding a lot.
Re: CF reinforced nylon!! January 04, 2017 08:54AM |
Origamib
The problem with carbon fiber filament is that the fibers are not giving anisotropic strength to the part, they are only giving strength in the XY plane, which if your printer is set up correctly will already be terrifically strong.
If you want awesome strength, consider annealing. Even PLA performs well with annealing.
Re: CF reinforced nylon!! January 04, 2017 08:34PM |
Origamib
Re: CF reinforced nylon!! January 06, 2017 04:13AM |
Re: CF reinforced nylon!! January 06, 2017 07:09AM |
Re: CF reinforced nylon!! January 07, 2017 03:27AM |
Re: CF reinforced nylon!! January 07, 2017 09:29AM |
Re: CF reinforced nylon!! January 07, 2017 09:40AM |
Re: CF reinforced nylon!! January 07, 2017 10:51AM |
