Cooling with an air pump? January 04, 2017 06:18PM |
Re: Cooling with an air pump? January 04, 2017 08:57PM |
Re: Cooling with an air pump? January 05, 2017 02:14AM |
Re: Cooling with an air pump? January 05, 2017 03:03AM |
Re: Cooling with an air pump? January 05, 2017 03:05AM |
Re: Cooling with an air pump? January 05, 2017 04:34AM |
Re: Cooling with an air pump? January 05, 2017 09:34AM |
dc42
There is also a commercial implementation available called Berd Air.
If you connect anything other than a brushless DC fan to a fan output of your electronics, connect a flyback diode in parallel with it to protect the fan mosfet.
Re: Cooling with an air pump? January 05, 2017 09:54AM |
An axial fan is not able to create the kind of pressure you need. Even a stronger radial fan won't help, it will need a pump. The fan will just sit there creating turbulences. Fans are meant to move large volumes at low pressure. Pumps are meant for low volumes at high pressure. The smaller the diameter of a pipe the higher the pressure you need to transport any usefull volume of air.Quote
icefire
What about using a 140mm fan with an air duct blowing air into the tubing instead of a pump? This would make it easier compared to a mains powered aquarium pump.
Re: Cooling with an air pump? January 05, 2017 11:34AM |
Re: Cooling with an air pump? January 05, 2017 02:53PM |
Re: Cooling with an air pump? January 05, 2017 03:35PM |
Re: Cooling with an air pump? January 05, 2017 03:50PM |
Re: Cooling with an air pump? January 05, 2017 04:28PM |
Re: Cooling with an air pump? January 05, 2017 07:59PM |
Re: Cooling with an air pump? January 09, 2017 03:41AM |
Re: Cooling with an air pump? January 09, 2017 04:29AM |
Re: Cooling with an air pump? January 09, 2017 05:51AM |
Re: Cooling with an air pump? January 09, 2017 08:47AM |
LoboCNC
One thing to note with ring-type blowers that attempt to blow air at the nozzle from all directions, by virtue of symmetry, the air velocity right at the nozzle tip must be zero.
Re: Cooling with an air pump? January 09, 2017 11:23AM |
Re: Cooling with an air pump? January 09, 2017 10:20PM |
Re: Cooling with an air pump? January 09, 2017 11:01PM |
Re: Cooling with an air pump? January 10, 2017 09:52AM |
Is it something like this [www.sparkfun.com] ? or much stronger?Quote
the_digital_dentist
CPAP machines use turbine type blowers with brushless DC motors.
Re: Cooling with an air pump? January 10, 2017 10:10AM |
Re: Cooling with an air pump? January 11, 2017 06:53PM |
Re: Cooling with an air pump? January 14, 2017 02:26PM |
Srek
icefire
Re: Cooling with an air pump? January 14, 2017 02:58PM |
Why not turning that big Fan 180° and let him suck like your vacuum cleaner?
That should be much more effectly.
Re: Cooling with an air pump? January 31, 2017 11:53AM |
Re: Cooling with an air pump? January 31, 2017 02:40PM |
Re: Cooling with an air pump? February 01, 2017 10:46AM |
Re: Cooling with an air pump? February 01, 2017 12:49PM |
Lykle
Clever!
Using solder as a support while bending.Way to go Mike.
I just received the pump, man it is big! Alas, no time to start using it. I want to do this right.
But since the Nimble is now selling, I am running ragged designing additional adaptors left right and center.
But man oh man, what a good idea using the solder. My tubing is 2.9 and managed to get a 90 deg angle bent without problems, but did not want to start on the loop.
And of course, I then realised I need to start with the loop to make it fit the effector I designed for it.
I put that effector up on Thingiverse, in STL and STEP format so that it is easier to modify the model if anybody wants to.
