Re: Cooling with an air pump? February 06, 2017 05:40AM |
Re: Cooling with an air pump? February 06, 2017 06:20AM |
Re: Cooling with an air pump? February 06, 2017 10:33AM |
Re: Cooling with an air pump? February 06, 2017 12:13PM |
Re: Cooling with an air pump? February 08, 2017 01:03PM |
Re: Cooling with an air pump? February 08, 2017 02:56PM |
Re: Cooling with an air pump? February 08, 2017 05:28PM |
Re: Cooling with an air pump? February 09, 2017 02:08AM |
Re: Cooling with an air pump? February 09, 2017 04:36AM |
JamesK
Based on recent experiments, I think the slot needs to be narrower compared to the tube diameter. I made some printed rings similar to what you have done, and all the air escaped from the side nearest the air inlets
Re: Cooling with an air pump? February 09, 2017 07:51AM |
Re: Cooling with an air pump? February 09, 2017 08:17AM |
Re: Cooling with an air pump? February 09, 2017 10:13AM |
Re: Cooling with an air pump? February 09, 2017 10:15AM |
Re: Cooling with an air pump? February 09, 2017 10:31AM |
leadinglights
Air from the aquarium pump is blown through a stainless steel tube which is heated with a propane torch and fed to the air ring.
Unfortunately this experiment was curtailed when the burning wood started coming out of the air ring
As it is too cold in the workshop to do much more...
Re: Cooling with an air pump? February 11, 2017 08:23AM |
Re: Cooling with an air pump? February 11, 2017 09:08AM |
Re: Cooling with an air pump? February 11, 2017 12:50PM |
Re: Cooling with an air pump? February 11, 2017 01:02PM |
Re: Cooling with an air pump? February 12, 2017 01:59AM |
Re: Cooling with an air pump? February 12, 2017 05:55AM |
Re: Cooling with an air pump? February 12, 2017 10:50AM |
Re: Cooling with an air pump? February 12, 2017 02:20PM |
Re: Cooling with an air pump? February 13, 2017 02:48AM |
Re: Cooling with an air pump? February 13, 2017 02:56AM |
Re: Cooling with an air pump? February 21, 2017 07:34PM |
leadinglights
That is an amazingly small pipe but must be adequate from the bridges.
If I understand his posting, cozmicray is suggesting using a vacuum. I think that this may be an idea worth trying although the geometry of air flowing out of a nozzle is not the same as air going into a hole, Brian's results would seem to indicate that success needs not much more than a gentle breeze - not a whole house vacuum, sorry cozmicray.
Mike
Re: Cooling with an air pump? February 21, 2017 09:48PM |
Re: Cooling with an air pump? February 23, 2017 04:09AM |
simspeed
What would be the best approach to connecting a pair of 12v air pumps to a 24v printer? Would it be better to use a 12v power supply like this? Thanks....
Re: Cooling with an air pump? February 23, 2017 12:10PM |
Re: Cooling with an air pump? February 25, 2017 05:29PM |
Re: Cooling with an air pump? February 26, 2017 03:07PM |
simspeed
The pumps don't appear to draw much amperage so they may work on the main power supply considering that my heat bed is mains powered. I guess I could run two SSR controllers and use the small power supply packs instead. I'm actually planning to run 3 pumps; one for the part cooling, one for the hot end heat break, and the last for the XY steppers that are mounted inside the heated enclosure.
