Re: NEWBIE January 09, 2017 10:22AM |
Re: NEWBIE January 09, 2017 10:44AM |
Re: NEWBIE January 09, 2017 11:17AM |
Re: NEWBIE January 09, 2017 11:23AM |
Re: NEWBIE January 09, 2017 11:42AM |
Re: NEWBIE January 09, 2017 04:19PM |
oap70
Hi James:
Mechanical design for last 30yrs (now retired): running Solidworks since 2000 (still using!!!): first used 3D printing for prototypes via UK agency in 2000: created some replacement vintage Christmas decorations (1940's) 6 months ago using my local college printers: Just looking to purchase a starter printer (filament) for some development gameplay components: The Mendel seemed reasonable and have no interest in "Specials" (great though they probably are): However can you provide a short list of standard machine kits (5 only) showing cost vs accuracy between 500 to 1000 pounds sterling and where in the UK they can be purchased please.
Re: NEWBIE January 10, 2017 03:17AM |
Re: NEWBIE January 11, 2017 02:05AM |
nebbian
Also note, the Kossel Mini kit recommended above uses the controller that DC42 sells. So it's hardly an unbiassed recommendation.
Re: NEWBIE January 11, 2017 05:38AM |
Re: NEWBIE January 11, 2017 06:59AM |
Re: NEWBIE January 11, 2017 11:41AM |
Re: NEWBIE January 11, 2017 12:47PM |
Re: NEWBIE January 11, 2017 01:14PM |
DjDemonD
Mike, have you thought about re-arm for your mega to 32bit conversion?
oap70
...... This is a prototyping tool only for me to run design reviews of miniature buildings and spacecraft......
Re: NEWBIE January 11, 2017 08:23PM |
DjDemonD
Nebbian - sounding frustrated buddy how about a corexy?
Re: NEWBIE January 12, 2017 04:31AM |
Re: NEWBIE January 12, 2017 09:59AM |
DjDemonD
They are not without their headaches, you're still tying two motors kinematics together, though this is an order of magnitude less complex in fault diagnosis than with 3 motors. I think so long as the x and y belts have equal tension meaning the x and y axes are orthogonal, and so long as you have a reliable z mechanism then you get good, fast prints. My no. 1 printer though for quality is still the kossel XL not the corexy, even though the core xy now has mgn-12h rails also. Still the same problems on corexy if the belt paths are not perfectly 90 degrees /parallel where required, objects printed near the extremities are deformed.
Have you seen this kit? [smartfriendz.com]
