Quality of Parts February 14, 2011 10:13AM |
Re: Quality of Parts February 14, 2011 12:09PM |
Re: Quality of Parts February 14, 2011 12:32PM |
Re: Quality of Parts February 22, 2011 05:19AM |
Re: Quality of Parts February 22, 2011 06:50AM |
Admin Registered: 17 years ago Posts: 1,791 |
Re: Quality of Parts February 22, 2011 10:49AM |
Re: Quality of Parts February 22, 2011 10:19PM |
-Surface: Is it consistent or porous and does it need sanding?
Again depends on your definition.. In a car engine, a printed gear would last about 2 seconds. Maybe. If you're lucky. Low load against parts of similar material will be ok for a while but ABS is the same stuff that Legos are made from - it'll wear and break if you abuse it. That's ok, though - just print more.Quote
-Strength: If appropriate materials are used, are gears etc durable enough for repeated use?
Re: Quality of Parts February 23, 2011 02:11PM |
Re: Quality of Parts February 23, 2011 04:24PM |
Re: Quality of Parts February 23, 2011 06:48PM |
Re: Quality of Parts February 24, 2011 05:20AM |
Re: Quality of Parts February 24, 2011 12:27PM |
