Re: Hangprinter version 2 April 03, 2017 10:02AM |
Re: Hangprinter version 2 April 03, 2017 10:14AM |
Admin Registered: 16 years ago Posts: 13,888 |
Re: Hangprinter version 2 April 03, 2017 10:24AM |
Re: Hangprinter version 2 April 04, 2017 12:22PM |
Re: Hangprinter version 2 April 06, 2017 01:13AM |
Re: Hangprinter version 2 April 06, 2017 01:14AM |
Re: Hangprinter version 2 April 06, 2017 10:09AM |
Re: Hangprinter version 2 April 08, 2017 12:13AM |
tobben
@dlang There was already a link to this thread at [hangprinter.org] I included the old thread as well just now. Where did you want to find the link?
so do you think it would be possible to go to single-lines instead of doubled ones?Quote
tobben
1. I used double lines before I added the line buildup compensation to avoid missing steps due to line buildup and resulting over-tightening.
moving from steppers to regular motors/servos would make this easy, with them you don't have to actually measure the tension, you measure the amount of power you have to exert (how much power are you feeding the motors or the offset you feed to the servos) and assume that the tension has a pretty linear relation to the power being applied (assuming you aren't moving, and allowing for gravity when you are offcenter)Quote
tobben
2. No, I never thought about this. Hangprinter currently doesn't measure tension. It measures nothing other than hot end temp. Looking forward to see a lot of sensor experimentation!
Thanks, that gives me a reasonable idea. I'm thinking in terms of building one of these as my first 3d printer and then using it to build a replacement to tinker with design ideas on.Quote
tobben
3. The calculation is complicated and depends very much on random calibration errors. As a rule of thumb you can travel 1/3 of the distance from origo to anchor point along all three directions (when printing the first layer).
if the homing process is off, you should still be able to start a new print without loss of accuracy, you just run into problems being repeatable from print to print, right? Or am I misunderstanding the problem?Quote
tobben
4. Buildup of line on the spools, and calibration errors are the biggest ones I think. To get much better you also need to automate the manual homing process.
my thinking was that in operation, the lines are not allowed to become slack enough to matter. If they do become slack, then pinching the line between rubber wheels and having the rubber wheel rotate the sensor. This picture of a disassembled mouse shows the sensor wheels off to the right ( [cdn.instructables.com] ) the center of the shaft rubs against the mouse ball and there are optical sensors that detect the rotation of the 'jagged whell' end of the shaft.Quote
tobben
You're idea for line position sensing is a really good one I think. How would you keep friction between line and shaft when line gets slack? Would pinching with a rubber wheel work?
I was not suggesting changing the spool or gear diameter (although going to a smaller spool with the same gear diameter would provide more accurate positioning, if you take into account line buildup)Quote
tobben
Spool and gear diameter is hard to max out further without splitting bottom_plate into two prints or moving the stack of spool+gear sandwiches to a stationary unit in the ceiling.
I looked at the oDrive, nice idea but it's build to such levels that it's expensive :-) $60/motor is quite a bit,and given the limits of extruder speed, it's speed you won't be able to use. but the idea of being able to drive h-bridges for speed/direction and then have a line position sensor would up the accuracy quite a bit (line buildup wouldn't matter, you would measure hor far it moves and not care how much it's built-up. I may still order an oDrive, it looks like a really neat tool to have.Quote
tobben
We (me and friends in Gothenburg and Oslo) will try the second approach first. We'll test it with steppers and filament before going BLDC and pellets. We have too little time to test all three this spring, but oDrive alpha v3.2 goes into production on April 17, so there's plenty of opportunity to contribute on the BLDC side right now =)
Re: Hangprinter version 2 April 08, 2017 03:59AM |
Re: Hangprinter version 2 April 08, 2017 05:00AM |
thanksQuote
tobben
Ok, added links on all those sites.
I hadn't heard of that, I'll dig into itQuote
tobben
It's also possible to drive steppers in constant force mode =) See the Mechaduino Project and some ongoing discussion about that here: [www.facebook.com]
I've built three CNC machines (one kit, one from plans, one to my own plans), so I'm confident (or foolish) enough to tackle it :-)Quote
tobben
I don't recommend the Hangprinter as a first printer unless you're very confident with building open source hardware from before. The project is young and there's still only one functioning prototype in existence.
is that just due to 3d printers being sensitive to sub mm differences in height for the first layer?Quote
tobben
The printer has hard-coded into it the line lengths at origo. If you don't find the exact origo manually, it will start off that print with false assumptions about its current line lenghts. The consequences of this is not noticeable now on my current printer, since every other error drowns in the errors of the hard-coded values themselves. The worst thing about manual homing, I find, is getting consistent first layers.
Yes, an optical encoder combined with a very small diameter shaft so that the encoder wheel spins many times per inch. do the lines get slack enough to be slipping during normal operation? I refuse to sign up for facebook, so feel free to pass along any of my comments/ideas wherever they will helpQuote
tobben
So the mouse uses an optical encoder. That could be a good option. I know cheap commercial 2d printers also use optical. The Mechaduino uses a rotating magnet glued to the motor shaft.
do you have any idea how much force or how fast you need the motors to run? from what I've seen, it seems like even micro servos would probably provide enough force and speed for the horizontal lines (and with the worm gear, possibly even for the vertical lines, but there a simple open-loop stepper may be the easiest answer)Quote
tobben
A single-unit Hangprinter with light and strong BLDC motor is a goal for the future, but the high price of oDrive that you mention has convinced me to keep the steppers for my next prototype.
Re: Hangprinter version 2 April 10, 2017 09:57AM |
Re: Hangprinter version 2 April 13, 2017 06:42AM |
Re: Hangprinter version 2 April 13, 2017 06:48AM |
Re: Hangprinter version 2 April 13, 2017 06:51AM |
Re: Hangprinter version 2 April 13, 2017 06:56AM |
Re: Hangprinter version 2 April 13, 2017 07:36AM |
Re: Hangprinter version 2 April 13, 2017 11:25AM |
Re: Hangprinter version 2 April 20, 2017 10:53AM |
Re: Hangprinter version 2 April 20, 2017 03:19PM |
Re: Hangprinter version 2 April 21, 2017 10:32AM |
Re: Hangprinter version 2 April 21, 2017 11:08AM |
Re: Hangprinter version 2 April 24, 2017 05:52AM |
Re: Hangprinter version 2 April 25, 2017 03:59PM |
Re: Hangprinter version 2 April 25, 2017 07:46PM |
Re: Hangprinter version 2 April 26, 2017 11:59AM |
Re: Hangprinter version 2 April 26, 2017 03:21PM |
Re: Hangprinter version 2 April 27, 2017 04:09AM |
Re: Hangprinter version 2 April 27, 2017 05:19PM |
Re: Hangprinter version 2 April 28, 2017 05:46AM |
Re: Hangprinter version 2 April 28, 2017 05:55AM |
