Re: Hangprinter version 2
September 06, 2017 05:24PM
Awesome work! thumbs up I'll probably refer to this vid lots of times. Very efficient explanations! I'm quite impressed that you figured out all that from the fragmented info that I've posted winking smiley
Would it be lots of work for you to flip the D-sandwich in the video (or just put a note there)? I flipped the D-sandwich when I added the worm gear, so most builders will get this wrong, since it's not in the assembly manual on the blog. Zooming in on this pic shows you the sandwich stack with the flipped D:
Looking forward to more vids =D
torbjornludvigsen.com
September 06, 2017 06:06PM
Oh damn! I didn't even notice. I will add that to the next video.
September 07, 2017 07:03AM
So the D spool before I flip it, has the fishing line wrapped around it clockwise. When I flip it, should I re- wrap the line to make it run clockwise again, or should I just run the motor in the other direction? Thoughts? I think both would work, but I haven't tried either yet. My only concern would be the route the line would take to the rod ring would be different. Just a note, I did get the printer to print in it's current config, but I am interested to see how it does with it flipped.
September 07, 2017 12:31PM
I have been trying different things with the gear flipped over, but it is way to tight. I am not sure how you got it to fit in there. I am printing a new gear to see if that will make a difference.
September 08, 2017 02:44PM
In what way does it get too tight? Do you have a picture?
I vote for rewrappring the line. cool smiley
September 08, 2017 03:02PM
Re-wrapping it is!
It's where the worm gear meshes with the D gear. Its so tight the motor can't turn it. When you turn it with your fingers it's so tight it will lift the D gear. Did you print the D gear and worm gear in ABS by chance? The shrinkage of the ABS might give you just enough clearance to make it work..
Edited 1 time(s). Last edit at 09/09/2017 11:58AM by brotherchris.
September 08, 2017 03:06PM
I used PLA... Does your gear teeth tilt the right way?
September 08, 2017 03:10PM
I sometimes have similar problems because of the significant elephant-foot I give my prints when squishing down first layers. I fix this by cutting away the elephant foot with a knife.
September 08, 2017 03:12PM
But I usually have room to spare around my worms. Your worm looks really well printed. Hm... Mystery.
September 08, 2017 03:34PM
I have a hypothesis, I printed the frame out of ABS, it probably shrank. The gears are PLA/PETG. I had a PETG frame but I think I tossed it. So I can't compare. Any where close to your measurements? Any problems with the PLA frame getting to hot?
This is 202 mm
This is 192 mm
This is from the center post to the D motor hole is 32 mm
Edited 1 time(s). Last edit at 09/09/2017 11:57AM by brotherchris.
September 08, 2017 04:46PM
Well I think ABS is the culprit. I just got a worm gear off the printer. It is 1mm smaller at its largest diameter than PETG/PLA gear. 34.22 mm for ABS 35.24 for PLA/PETG.
Oh well, easy fix, just printing the D parts in ABS should solve the issue. I we get it fixed up and report back.
September 09, 2017 10:08AM
This is interesting, I don't have much experience with ABS myself. Never experienced problems with PLA frames getting too hot. If I plan on running motors above 50% of their max current, I use washers as spacers between motor and PLA, just to be safe.
September 09, 2017 10:17AM
Don't have any printed bottom plates here, but made a measurement in the Openscad model:
This is 204.6 mm.
September 09, 2017 10:31AM
Good to hear, I am back tracking with a PLA frame, I should have it up and running today, fingers crossed everything should fit better.
September 09, 2017 10:43AM
The black is ABS, the silver is PLA. It shrinks just enough to be a problem.
Also, I have no clue how to make these photos work correctly from google photos.
Edited 2 time(s). Last edit at 09/09/2017 11:53AM by brotherchris.
September 09, 2017 11:38AM
Nice! To post images, do the following but remove spaces within the square brackets.
[ img ]https://lh3.googleusercontent.com/jmpM5TYGUT77WRH0eHyYkFuUTMqd6IbMq_e_Qlf35A6EiZk_ddT5i3x5tWj1RB88i5Mkznpu7x6SueS8cwsvyXSLmVwgwnMwt8mTUpfERmTQBuWvoHzOdAHcuDIcv6JCPeAqFPsEHPfb3kjgTFmCk-GIYaMrkVqlAXWLE9qb8bdiECSYBac37NZPAJJR5I9uBEfR3grYEKv1d_5BPWQQtJqWug-vTL1D9PPMqF9BkeqiRr_Hgv-OjvsQ1sOJ_lR8wM4anOyIZ396T48RK-WppjPMsl-RpB0rfqDWhu0luakOd1hTA7w8erQ8ibgABKnBSSAXAsiQzhdgeRBSrcsK3VSGOlkynNlo6PQiVkBZMer_yiv_-E1o-D93Qm6nDzlR8yOq3QEH2cRST6ej2Qp5eoXJ9WlPvR9W3Y_4A5awXDofhp6H4W1AZSTsqObgvCdeTsizoR3LcrAj3bU1ZQn8PjBBb_0EEuEOsEK9ySBr25DWWqdJMY64CKXrPcR1jHmx4y0C8_NU2NhgJtQScTJNPBI3TXajOjM5Ij2WFL8QT5zyrX8lwqbcUeZm78SJOJn0qwiUf4tjdKwjth_3I0PQMNHsj4Bt6rDDqah5ZQvgTI24ROKmBcCQhHRCFnHaesyPGy7tpL_bMKHPxNUtzkwJZ21lYRmqiETgOUYhht6KZdGuVw=w895-h671-no[ /img ]
Got url by clicking image to get a larger version, then right click and choose "copy image location"
smiling smiley
September 09, 2017 11:53AM
Finally, I got it to work, thank you.
September 09, 2017 06:38PM
Well man, I am stumped, I have tried PLA PETG ABS, different motors. Different part configs, still can't get the D gear where it is lose enough to move on the worm gear when it is flipped over. Short of scaling down the parts a little, I am out of ideas. I'll keep thinking on it. There has to be something I'm doing wrong somewhere.
Edited 1 time(s). Last edit at 09/09/2017 11:59PM by brotherchris.
September 10, 2017 03:04PM
Oh no =O
Did a larger bottom plate not help at all?
Is the worm stuck all of the time, or is it stuck only at certain positions (parts of the rotation)?
Pics can help me help you diagnose the problem. (I can't open the close up that you posted earlier anymore, don't know why.)
September 10, 2017 03:11PM
I am currently trying to get the most perfect gear print I possibly can to see if that helps. I PLA frame didn't seem to help as much as I hoped. I am trying to tighten up the worm gear as evenly as possible, but I do get tighter parts than other as I roll the worm gear.
September 10, 2017 03:20PM
Lowering the extrusion rate by ca 1 % will probably help
September 10, 2017 08:44PM
I have made 2 of the most perfect PLA parts I have ever made. The worm gear and the D gear. It is still way to tight. I am now printing some with a 0.9 extrusion multiplier. I have also ordered some different 608 bearings...who knows.
Pic:
Video
Gear Video
September 12, 2017 07:53PM
Well it looks like the 608 bearing was off enough to cause the binding. I still think the lower extrusion multiplier helped as did the PLA frame. I think the gears fit well enough for me to continue. Thanks again for the help.
Video update here:
[youtu.be]
September 13, 2017 05:21AM
Wow, big respect for the grit in debugging this! You found not one but three potential causes of trouble, two of which are completely new to me. Most people would just have given up. Thanks!
Locking up so easily is of course a design bug. I made these two commits to mitigate that:
[github.com]
[github.com]
I also noticed that I've used very fragile code to avoid this bug before (see these five lines of code that I've used to compile stls). Implementing a more robust and automated build process for the stls.
Edited 1 time(s). Last edit at 09/13/2017 05:22AM by tobben.
September 13, 2017 07:45AM
Very nice, thanks for making these changes. This should help out others. I'll get some printed and try them out.
September 13, 2017 08:02AM
There: [github.com]
To generate all the stls from the scad-files type 'make' when you're in your hangprinter directory (tested using gnome terminal on an Ubuntu 16.04 box only) ((no need for you to actually do this now, the repo is already up to date)). I hope this reduces the risk of similar bugs returning on me in the future winking smiley
Best regards
Edited 1 time(s). Last edit at 09/13/2017 08:03AM by tobben.
September 13, 2017 11:11AM
So I reprinted the gear and tried it out. I think I could make it work on the ABS frame, but still pretty tight. Works well on the PLA frame that was printed with the extrusion multiplier set at .9. I recommend this setting anyway, it makes the screw holes easier to use.
September 19, 2017 02:38PM
Quick update, I got the calibration video done, not my best work, but it isn't easy to setup a Hang printer. winking smiley Now that it has a more permeate home I should be able to set it up and just let it print.
[youtu.be]
Edited 1 time(s). Last edit at 09/19/2017 02:38PM by brotherchris.
September 19, 2017 04:36PM
There's _lots_ of good work packed into that video.
I saw that the calculator gave you a #define ANCHOR_C_X NaN or something eye popping smiley I thought: "Bug alert! Somebody, get the one responsible for this! Oh that's me."
Did your printer move as expected anyways?
Love the clip when you're lowering the printer in fast-forward...
Looking forward to see your prints =)
What are your thoughts on the v3 and the direction we're taking with current development?
Parts for the mover on the right (thanks to Osika) are made such that they can be assembled in any order. Extruder will also be easily detachable. The little sliders (with white tape on the left mover) are the endpoints of lines. Sliding them back and forth makes it very easy to level/rotate printer without needing a screwdriver.
September 19, 2017 04:53PM
Thanks,
So, interesting that you noticed that. I had to move my C mount to 1500mm to get the calc to not say Not A Number. Anything under 1500 would cause this error. I didn't notice it until after the video was done. I didn't try to run it with these numbers, it appears to be moving well now. I thought maybe I had my mounts in such a way that caused an impossible calculation. So no clue what happened.
On Hang 3, I haven't had time to wrap my head around it yet. Not sure how the top plate works, so I need to catch up. I will work that in to my reading this week. The part movers look great though. I like the idea of the tabs you can adjust the lines with. I am defiantly on the search for a better way to do my hang2 extruder. That looks like a pretty nice direct drive on that one.
