Kapton tape and extruder nozzle.
Posted by Milly
February 17, 2011 03:47PM
I will be shortly putting together my extruder nozzle and am getting hold of the various bits and pieces I will need. I am wondering why high temperature tape (kapton) is used to hold the thermistor in place when the resistor is secured using high temperature glue or fire cement. Is there a good reason why the thermistor can't also be glued rather than taped? I only ask because its one less thing I have to source and order!
Thanks,
Milly.
Re: Kapton tape and extruder nozzle.
February 17, 2011 05:20PM
It definitely doesn't have to be taped. Taping it just makes it easy to remove if it gets broken or the leads snap off, since thermistors are rather fragile.
