Re: Filament sensor (Zesty Nimble et al) February 16, 2017 03:27AM |
nebbian
it doesn't detect when the filament makes its way out of the filament guide path (after the extruder gear)
Re: Filament sensor (Zesty Nimble et al) February 16, 2017 04:51AM |
Lykle
Since we are talking about the filament sensors, here is a preview of what we were planning.
The idea is that in the center there is a magnet rotating. Under that magnet is a sensor sensing the rotation.
On the left is a pressure wheel, pressing the filament against the magnet using a 3d printed "spring" in dark blue.
On the other side is a clip that will allow you to clip it to the Nimble.
The shape needs to be simple and easy to use. At the same time it needs to be symmetrical so it can be used on the left handed Nimble as well.
In this case you can do that by switching the two dark blue bits. Disadvantage of that is the fact that the sensor is then running "backwards"
The advantage of a modular approach like this is that the unit is not limited to the Nimble. Any attachment point can be used, simply by changing the mount block.
David (Escher3D) and Tony (Think3DPrint3D) are looking into this and working on the PCB. The method of getting the filament clamped and the magnet rotating is still looked into as my design is deemed too simplistic. These guys know what they are talking about so I will bow to their judgement. Still think it will work tho. :-)
Any comments?
Re: Filament sensor (Zesty Nimble et al) February 16, 2017 01:47PM |
Re: Filament sensor (Zesty Nimble et al) February 16, 2017 02:34PM |
Re: Filament sensor (Zesty Nimble et al) February 16, 2017 03:19PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 16, 2017 08:44PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 17, 2017 02:59PM |
nebbian
The wheel has already been invented:
Just sayin'
Re: Filament sensor (Zesty Nimble et al) May 04, 2017 05:23PM |
Re: Filament sensor (Zesty Nimble et al) May 13, 2017 10:42AM |
Re: Filament sensor (Zesty Nimble et al) May 13, 2017 12:15PM |
Re: Filament sensor (Zesty Nimble et al) May 14, 2017 02:23AM |
Re: Filament sensor (Zesty Nimble et al) May 14, 2017 03:26AM |
Re: Filament sensor (Zesty Nimble et al) May 14, 2017 03:49AM |
Re: Filament sensor (Zesty Nimble et al) May 15, 2017 05:05AM |
Re: Filament sensor (Zesty Nimble et al) May 15, 2017 03:49PM |
Re: Filament sensor (Zesty Nimble et al) May 19, 2017 03:58AM |
Re: Filament sensor (Zesty Nimble et al) May 20, 2017 01:40AM |
Re: Filament sensor (Zesty Nimble et al) May 20, 2017 09:31AM |
Re: Filament sensor (Zesty Nimble et al) May 27, 2017 05:15PM |
Re: Filament sensor (Zesty Nimble et al) May 29, 2017 03:34AM |
Re: Filament sensor (Zesty Nimble et al) May 29, 2017 06:27AM |
Re: Filament sensor (Zesty Nimble et al) May 29, 2017 07:18AM |
Re: Filament sensor (Zesty Nimble et al) May 30, 2017 06:56AM |
RGN01
Yes, that's it! I well remember working on those many years ago.
Richard
Re: Filament sensor (Zesty Nimble et al) May 31, 2017 12:02PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) June 01, 2017 03:29AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) June 01, 2017 11:35AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) June 02, 2017 07:02PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) June 04, 2017 04:58AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) June 04, 2017 05:24AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) June 04, 2017 05:31AM |
