Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 23, 2017 05:49PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 23, 2017 06:11PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 23, 2017 06:36PM |
. Flex3Drive is the original, and superior product. Once my focus turns outward again all will be good. too many hats to be worn and not enough hours.|
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 24, 2017 06:24AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 24, 2017 05:47PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 25, 2017 02:46AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 25, 2017 03:02AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 26, 2017 07:49AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 29, 2017 02:02PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) January 30, 2017 07:06AM |
Help for the Nimble February 06, 2017 03:43AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 08, 2017 11:46AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 11, 2017 01:07PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 12, 2017 04:57AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 12, 2017 09:56AM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 12, 2017 01:18PM |
Filament sensor (Zesty Nimble et al) February 15, 2017 03:00AM |
Re: Filament sensor (Zesty Nimble et al) February 15, 2017 03:09AM |
Re: Filament sensor (Zesty Nimble et al) February 15, 2017 05:26AM |
nebbian
Looks pretty good to me Lykle!
One issue with that class of design is that it doesn't detect when the filament makes its way out of the filament guide path (after the extruder gear) and bypasses the hotend altogether. I've had a few of these failures lately, it would be great if there was some way of detecting that the filament is no longer going through the hotend. I've no idea how to do that, however!
Re: Filament sensor (Zesty Nimble et al) February 15, 2017 09:44AM |
Origamib
Design a better path for the filament? I have only ever had this when either changing filament mid print and I don't pause the print, or ninjaflex. I'm still yet to find a decent way to print this horrible stuff.
Re: Filament sensor (Zesty Nimble et al) February 15, 2017 11:22AM |
nebbian
Origamib
Yeah, flexible filaments. I'm using TPE, which (I think) is softer than ninjaflex.
If there was a way to detect filament flow (or pressure) _after_ the extruder, then it would be really useful for me.
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 15, 2017 12:25PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 15, 2017 01:01PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 15, 2017 03:05PM |
RGN01
I am now able to print 0.2mm PLA layers easily, 0.1mm about 80% of the time. The other 20% fail within the first layer or two and appear to be when the fist layer does not adhere properly or has inconsistencies in height.
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 15, 2017 03:50PM |
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 15, 2017 03:53PM |
briangilbert
RGN01
I find using multiple processes with S3D makes printing with very small layer heights infinitely simpler, print first layer at 0.2mm then so far, I've gone as low as 0.05 for the rest successfully.
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 15, 2017 11:34PM |
o_lampe
An indirect way of sensing filament jam would be to observe (Firmware-internal) the relation between extruder heater-PWM and extruded material.
A sudden drop in PWM indicates that no new filament reaches the heating chamber, while the extruder is still pushing. That won't work immediately after mid-print temp changes, but it's a starting point ( and its for free)
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 16, 2017 01:33AM |
o_lampe
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 16, 2017 02:44AM |
I was happy with this spark of geniality myself because it came out of the blue.Quote
RGN01
This gradual slow down is more of a concern to me as a complete break is easy to detect with a micro switch.
It also seems that it would require an appreciable amount of processing power and that may make it non-viable for lower powered controllers.
Re: Remote Direct Drive effectors for E3D Chimera / Cyclops (Zesty Nimble et al) February 16, 2017 03:19AM |
