Using the Duet Sheild outputs to drive extra axes
January 25, 2017 09:45AM
Hi, I hope I'm putting this in the right forum.
I have a single extruder reprapro Mendel 3 with Duet Controller and a Duet Sheild. The duet sheild has extra outputs for 2 additional extruders and I'm trying to use the M584 command to configure these as U and V axes drivers. This takes the form M584 Un Vn, where n is the relevant drive number. However, the documentation for the Duet Shield does not (that I have found) contain any information on what the drive numbers are in firmware. Does anyone know?
Re: Using the Duet Sheild outputs to drive extrahttp://forums.reprap.org/index.php axes
January 25, 2017 11:52AM
There is a dedicated forum for the Duet in the Controllers section of these forums.
For the Duet 0.6 + Duet shield, the X,Y,Z,E0 drivers on the Duet are numbers 0-3 respectively (although you connect to E0 via the shield) and the E1 and E2 motor outputs on the shield are numbers 4-5. I think the one nearest the expansion connector is E1 i.e. 4.
Can you confirm you really are adding additional axes, not just additional extruders? If you are just adding extruders, you don't need the M584 command.
HTH David
Edited 2 time(s). Last edit at 01/25/2017 11:53AM by dc42.
Hi thanks for the quick response, I'll have another go at identifying them based on that tomorrow.
Yes, adding two axes. Have been passed the hardware with a second extruder mounted, and am going back to single extruder and adding axes.
Thank you
Thank you very much David.
That worked first time once I had the right drive numbers in my config.
I can confirm that the stepper connection nearest the expansion header connector on the Duet Shield is number 4, the one immediately to the right (above the 3 indicator LEDs) is 5. At least with a Duet 0.6.
Marnoch
