Hall Effect Senor
Posted by tim3716
Hall Effect Senor
January 26, 2017 12:23PM
I am planning on making my own hall effect sensor with a A3144 sensor, but I am a bit confused on the wiring. Can you just wire it directly? A lot of other designs seem to have resistor and capacitors, and I dont know what their purpose is.
Re: Hall Effect Senor
January 28, 2017 01:25PM
Not advisable to wire directly. Hall effect sensors usually give analog output, proportional to distance of magnetic field.
All the solutions I have seen have an adjusting knob, that means you can set a point where the output is triggered to give a definite digital response to the endstop input on your controller.
If you wire direct, you will have to set up manually, and that is a recompilation job every time you want to adjust! Lots more work.
It's worth paying the few pounds extra for a board with an adjustable threshold. Saves a lot of messing about.
January 28, 2017 01:33PM
The A3144 is a digital output Hall sensor, so you can wire it directly to an endstop connector. It needs 5V power. You should connect a 100nF capacitor between the Supply and Ground pins, close to the sensor. The output will go low when a magnet is near, so if you are using it as an endstop, this is the opposite of a normally-closed switch.
January 28, 2017 03:54PM
OK. But if the "near" factor isn't the right distance, you will have issues adjusting the distance. That is my concern - what do you do, use a bigger magnet if too close? Or a smaller magnet if it is too distant? Regular units you can adjust very easily. I really do not know how you would go about that with a digital sensor - how else do you adjust the trigger threshold if you wire it directly?
Edited 1 time(s). Last edit at 01/28/2017 03:56PM by DragonFire.
