A new printer to explore the vacuum plate build stage January 29, 2017 06:24AM |
Re: A new printer to explore the vacuum plate build stage January 29, 2017 08:38AM |
Re: A new printer to explore the vacuum plate build stage January 29, 2017 09:54AM |
Re: A new printer to explore the vacuum plate build stage January 29, 2017 01:21PM |
Re: A new printer to explore the vacuum plate build stage January 29, 2017 02:07PM |
Re: A new printer to explore the vacuum plate build stage January 29, 2017 03:19PM |
leadinglights
I am trying to take thermal expansion into account, so far the biggie is that the CoE of Acrylic is about three times that of Stainless Steel, Aluminium etc.. I had not thought of potential problems with the carbon fiber rods but as there is little depth to the specifications available for this sort of thing I thing much of my time will be spent seeing if various components will work at an elevated temperature. I did think of potential problems with the linear bearings but ones like LM10 are likely to be less temperamental than precision guides.
One thing in our favour though is that many components will actually work satisfactorily at temperatures well above their published maximum - I use WW resistors in preference to cartridge heaters and have used them up to 300°C while their published tmax is 180°C
Mike
Re: A new printer to explore the vacuum plate build stage January 30, 2017 09:00AM |
