use of codec to speed up gcode operations February 25, 2011 08:38PM |
Re: use of codec to speed up gcode operations February 25, 2011 10:00PM |
Re: use of codec to speed up gcode operations February 25, 2011 10:36PM |
Admin Registered: 15 years ago Posts: 1,470 |
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: use of codec to speed up gcode operations February 26, 2011 12:04AM |
Re: use of codec to speed up gcode operations February 26, 2011 03:20PM |
Re: use of codec to speed up gcode operations February 26, 2011 07:06PM |
Re: use of codec to speed up gcode operations February 26, 2011 09:36PM |
Re: use of codec to speed up gcode operations April 04, 2011 12:14AM |
Re: use of codec to speed up gcode operations April 04, 2011 04:28PM |
Re: use of codec to speed up gcode operations April 04, 2011 05:27PM |
Re: use of codec to speed up gcode operations April 04, 2011 09:00PM |
Re: use of codec to speed up gcode operations April 05, 2011 12:54PM |
Re: use of codec to speed up gcode operations April 06, 2011 01:49AM |
Re: use of codec to speed up gcode operations April 08, 2011 08:48PM |
Re: use of codec to speed up gcode operations April 10, 2011 04:47AM |
Re: use of codec to speed up gcode operations April 10, 2011 06:19PM |
Re: use of codec to speed up gcode operations April 12, 2011 12:11AM |
patbob
As for compression and error correction ... ... both make debugging the firmware harder since one cannot use simple programs to manually send commands to it.
Again pretty green here but there does not appear to be a way to ask current firmware what it's capabilities are. This should start being implemented IMHO. Instead of negotiating and trying to load multiple codecs/interpreters onto the arduino why not have new firmwares broadcast codec they support when they boot up. Then the host can just pick the right plugin. I guess legacy firmware would be identified by "start", newer firmwares would broadcast something like "start jdcodecv01".Quote
patbob
BTW, is there any chance you can make the firmware autonegotiate FEC/no-FEC with the host SW, preferably in a way that's backward compatible to old host SW?
Re: use of codec to speed up gcode operations April 12, 2011 01:49AM |
Re: use of codec to speed up gcode operations April 12, 2011 05:53AM |
Re: use of codec to speed up gcode operations April 12, 2011 06:24AM |
Re: use of codec to speed up gcode operations April 12, 2011 06:58AM |
Re: use of codec to speed up gcode operations April 12, 2011 05:44PM |
Re: use of codec to speed up gcode operations April 13, 2011 10:36AM |
Re: use of codec to speed up gcode operations April 13, 2011 10:41AM |
Re: use of codec to speed up gcode operations April 13, 2011 03:14PM |
Re: use of codec to speed up gcode operations April 16, 2011 12:00PM |
Re: use of codec to speed up gcode operations April 18, 2011 11:15PM |
