Re: Cloned titan extruder review/opinion... June 17, 2018 11:00PM |
Re: Cloned titan extruder review/opinion... June 17, 2018 11:32PM |
Re: Cloned titan extruder review/opinion... June 18, 2018 03:45AM |
Re: Cloned titan extruder review/opinion... June 18, 2018 09:30AM |
Re: Cloned titan extruder review/opinion... June 19, 2018 12:07AM |
Re: Cloned titan extruder review/opinion... June 20, 2018 09:22AM |
Re: Cloned titan extruder review/opinion... June 20, 2018 09:33AM |
Re: Cloned titan extruder review/opinion... June 30, 2018 05:48AM |
CHBRIGHT83
can you see if the original titan top fits? what i saw was that my cloned plastic titan had everything offest. this included the hobbed gear as you described, the filiment hole didnt line up with the hobbed gear very well. the hobbed gear was offset and the filiment wouldnt go straight from the hobbed gear to the hole feeder hole. sounds exactly like what you described here.
when i tried to fit an aero top it didnt line up. i have an aluminum set on order and hope my aero top fits.......
Re: Cloned titan extruder review/opinion... July 05, 2018 04:58AM |
Re: Cloned titan extruder review/opinion... July 05, 2018 07:21AM |
flydeprutten
I have now lubricated it, but I'm considering drilling the hole bigger and inserting a nylon or ptfe tube between the shaft and the hole.
Re: Cloned titan extruder review/opinion... July 05, 2018 07:22AM |
Re: Cloned titan extruder review/opinion... July 05, 2018 07:48AM |
the_digital_dentist
If the motor shaft has a flat on the surface, the edges are probably sharp, and it's those edges that are chewing up the hole in the pinch roller lever. Use a file or sandpaper to reduce the sharpness.
Re: Cloned titan extruder review/opinion... July 05, 2018 03:06PM |
the_digital_dentist
Re: Cloned titan extruder review/opinion... July 05, 2018 05:41PM |
Re: Cloned titan extruder review/opinion... July 06, 2018 02:53AM |
the_digital_dentist
I wouldn't use any lube except graphite or silicone grease. Petroleum based grease may attack the plastic.
E3D was having problems with the grease getting out of their bearings and onto the polycarbonate front cover of the Titan extruder and causing it to crack.
Re: Cloned titan extruder review/opinion... July 06, 2018 03:10AM |
Re: Cloned titan extruder review/opinion... July 06, 2018 04:12AM |
MKSA
Grease and similar non dry lubricant will collect dirt, grit, may end up on the hobb ... and are better avoided. The design must use either closed ball bearing, polymer bushings ....
Re: Cloned titan extruder review/opinion... July 08, 2018 02:03PM |
Re: Cloned titan extruder review/opinion... July 08, 2018 09:55PM |
Re: Cloned titan extruder review/opinion... August 12, 2018 03:53PM |
the_digital_dentist
I ordered an aluminum Titan from a Chinese supplier and immediately set about modifying it to work better before I ever tried printing with it.
Re: Cloned titan extruder review/opinion... August 12, 2018 04:29PM |
Re: Cloned titan extruder review/opinion... August 16, 2018 07:18AM |
Re: Cloned titan extruder review/opinion... August 16, 2018 09:47PM |
Re: Cloned titan extruder review/opinion... August 17, 2018 12:03AM |
Re: Cloned titan extruder review/opinion... August 18, 2018 11:14AM |
Re: Cloned titan extruder review/opinion... August 19, 2018 09:11AM |
Re: Cloned titan extruder review/opinion... August 19, 2018 02:22PM |
Re: Cloned titan extruder review/opinion... August 27, 2018 03:46AM |
yeap and the dust is even nastier, not something I want to be sat near!. took a panther to reveal the problem.Quote
2) the hole in the pinch roller lever that fits over the motor shaft was worn and out of round. There was a considerable amount of black dust (aluminum?) inside the body of the extruder.
Re: Cloned titan extruder review/opinion... September 05, 2018 04:10PM |
mcdanlj
Perhaps ... using an MR58 bearing would work well.
Re: Cloned titan extruder review/opinion... September 05, 2018 04:31PM |
