Engineering type question March 13, 2017 12:02AM |
Re: Engineering type question March 13, 2017 02:53AM |
Re: Engineering type question March 13, 2017 03:49PM |
Re: Engineering type question March 14, 2017 01:53PM |
Re: Engineering type question March 14, 2017 09:14PM |
Re: Engineering type question March 27, 2017 06:21AM |
Re: Engineering type question give up on the cheapest April 02, 2017 07:17PM |
Re: Engineering type question April 05, 2017 05:42PM |
n9jcv
If I were to have metal parts made by a CNC shop, at the cheapest rate, what tolerance could I expect. For example, if my file calls for a 5mm hole, what would be acceptable 4.8 -5.2mm?? Again, I have no idea of what is typical.
n9jcv
If designing a hole, that is supposed to have a rod go thru it, but be held tightly, like a 8mm rod and a hole, If I call for my hole to be 8.1mm is that enough of a gap to fit or do I need more clearance.
n9jcv
If I have a 5mm screw, that I want to thread the hole for, should I spec the hole at 4.5mm and then tap it or spec it smaller or larger?
