Hello, how are you people?
Im looking for help with the design of a upgrade bed from my prusa i3 rework.
Actually the bed iam using is a 200x200mm heat bed and the length of the threaded rod is 38cm on the Y axis. and the smooth rod 35cm.
How long must be the rod threaded and smooth rod that will need to be able to install this larger bed And that it can print correctly on its entire surface?
Thanks!
