Stuck March 21, 2017 07:22PM |
Re: Stuck March 21, 2017 07:59PM |
Ahhh, the piece I forgot to mention is that I cannot find an 8mm 16t pulley. Besides, that would be 21 dollars a piece per smooth rod but they would be dead straight as Mitsumi doesn't play around so they can conform to g6/h5 tolerances.Quote
MechaBits
Dual shaft motor, in the middle of 2 300mm rods...go for 8mm thicker/shorter less chance of bends in the post but still possible, or join two pieces with a coupler, or step back down to 5mm up to you.
Re: Stuck March 21, 2017 09:07PM |
Interesting on the 12mm being crappier than 8mm but I haven't had luck with eBay or even worse Aliexpress or even worse yet Banggood. As far as the 16t I have been using them since I got into 3d printing 4 years ago as there are no round off errors with them and they offer finer resolutions. At 16 micro stepping 16t is 10 micron and 20t is 12.5 micron resolution so finer and no rounding errors thanks to that .5. It does matter ever so slightly the smaller the nozzle diameter gets.Quote
MechaBits
I got quite a few 8mm's from cheap ebay listings...not had one reject...but I have with 12mm rods,
why you wanting 16t?
Re: Stuck March 21, 2017 09:36PM |
If I had a lathe you bet I would have turned down 8mm rod but I don't and I am not sure what you mean on your second bit there? This is why I started this thread for suggestions because right now I can reprint all of my parts and make a big Core X/Y (not something I really want to do) because it doesn't demand a rod like that or find some way I can pull that extrusion beam from both sides using just one motor that doesn't involve a rod that always seems to be bent.Quote
scottybfg
If you only need it to be 5mm so the pulley will fit on the end why not get a bigger diameter and turn down the ends? I know not easy with a long rod but can be done.
Or use small bits of 5mm for the pulley and then use a coupler to step up to the diameter of the straightest rod you can find, a pillow block each side of the coupler should keep it aligned
Re: Stuck March 21, 2017 10:29PM |
Yep, I was thinking the same but trying to get anything that is straight is a nightmare if less than 8mm. If I had a lathe I would easily turn it down to 7.9mm for 100mm and the last 30mm would be 4.9mm but I just don't have it. The X moves so smoothly by itself and even with an idler pulley but attach the rod and it feels like I am on the old Chisholm trail in a wagon with a broke axle.Quote
scottybfg
So my thinking is you only need 5mm where the pulleys are needed, and what you are trying to make is just one big drive axial, so use 5mm for where the pulleys need to be placed and then use a coupler to join it to a rod of another diameter that is straight. Using pillow blocks ( bearings) to help align the shaft.
See bad paint drawing for reference
Re: Stuck March 21, 2017 11:06PM |
Yeah, 8mm from mitsumi was dead straight and true but anyway I am intrigued at what you said. Could you go more indepth and possibly show a picture, or two, as I am not fully grasping how it would be done.Quote
scottybfg
I also find it hard to believe that you can t find 2 sections of 30mm to 40mm 5mm straight rod, or maybe I have been blessed with my suppliers of smooth rod (usually use 8mm or 10mm)
The only other thing i can suggest is to use flex couplers to take some of the miss alignment of the shaft. Or as there is only radial load, use a flexable shaft that is constrained by the pillow blocks. you might have to use more bearings but you you cant find straight shaft this might be the way to go.
Re: Stuck March 22, 2017 12:01AM |
Info on a flex system would be nice as well and since all of these will be printed and on the extrusion they will be as aligned as I will ever be able to get them.Quote
scottybfg
[attachment 92248 Untitled1.png]
This was the first idea I was talking about, or did you want info on a flex system? (EDIT: My numbers for the length of the 5mm rod might be a bit off, you could almost half them)
Also have you looked at carbon fibber rod? It has a bit of play so as long as your pillow blocks where aligned correctly you could force it to be straight
Re: Stuck March 22, 2017 12:09AM |
88625K64 and twice it came with rust on it to the point it was pitted over a 1/3 of it. First order from them and not all that happy with them.Quote
LoboCNC
What McMaster part number were you ordering for 5mm rods? Did you look at the linear shafting (6112K13) which has a 0.03mm/300mm straightness tolerance?
Re: Stuck March 22, 2017 12:13AM |
Re: Stuck March 22, 2017 12:18AM |
Re: Stuck March 22, 2017 12:32AM |
Re: Stuck March 22, 2017 12:40AM |
Re: Stuck March 22, 2017 12:43AM |
Re: Stuck March 22, 2017 12:57AM |
Re: Stuck March 22, 2017 01:03AM |
The only thing I could find doing anything like that was a Core XY though not closed belts. I really don't care if closed is required as long as something could be done that would eliminate the smooth rod axle.Quote
scottybfg
well, it could be done with one closed loop belt to drive the 2 pulleys
