E3D Aero, hot or not? March 24, 2017 09:48AM |
Re: E3D Aero, hot or not? March 25, 2017 11:48AM |
Re: E3D Aero, hot or not? March 25, 2017 11:59AM |
MechaBits
An interesting development but in order for me to buy something like this, I would need holes in right place for mounting direct to a linear carriage and belt attachment points in the right place, which I have no idea where at the moment, so at the very least enough holes in various places for additional brackets. Just as this solution appear Bondtech bring out another, wonder if they will need to update theirs? They dont seem to have a flexi-cable version even though the description almost sounds like it should have.
Re: E3D Aero, hot or not? March 25, 2017 12:27PM |
Re: E3D Aero, hot or not? March 25, 2017 01:24PM |
Re: E3D Aero, hot or not? March 25, 2017 05:00PM |
Origamib
What annoys me is why nobody ships an extruder with a fan?! E3D have been making their hotends for years and have not once considered making a part cooling fan that integrates with hotend+extruder?
Re: E3D Aero, hot or not? March 25, 2017 08:43PM |
Origamib
Re: E3D Aero, hot or not? March 25, 2017 08:53PM |
ElmoC
Origamib
There are so many different ways to mount a part cooling fan. Makes it hard to come up with something generic enough. Guess you could ask the same question; why don't they ship with a carriage?
Re: E3D Aero, hot or not? March 25, 2017 08:57PM |
Origamib
ElmoC
Origamib
You are right, but a part cooling fan should be much more generically viable for many people, whereas carriages are not. There is no reason why e3d shouldnt be able to supply a part cooling fan as part of their ecosystem on either the hotend or extruder.
Re: E3D Aero, hot or not? March 25, 2017 09:05PM |
Mutley3D
Origamib
Flex3Drive ships with hotend cooling and print cooling solution using 25mm fans as standard
Re: E3D Aero, hot or not? March 26, 2017 07:49AM |
ElmoC
Origamib
ElmoC
Origamib
How a part cooling fan is mounted will depend on the carriage. From what I see, part cooling fans are far from generic, just like carriages.
So, what would you suggest E3D ship with the hot ends for a part cooling fan setup?
Re: E3D Aero, hot or not? March 26, 2017 09:55AM |
Origamib
ElmoC
Origamib
ElmoC
Origamib
It should be an optional extra with a mounting point on either the fan shroud or on the titan. There are many places it could go and be suitable for the majority of printers. Check out djdemond compact fan mount for an idea that would be suitable for most printers.
In general the titan is poorly designed in regards to mounting it, or accesories. You need access to 3 sides of it (gear, idler tension and of course hotend), meaning mounting is annoying. Just sayin'.
Edit: There are even less mounting point options on the aero.
Re: E3D Aero, hot or not? March 26, 2017 01:26PM |
Re: E3D Aero, hot or not? March 26, 2017 01:29PM |
Origamib
ElmoC
Origamib
ElmoC
Origamib
ElmoC
Origamib
In my experience, the titan's design is no different than any other extruder I have used. The mounting is very simple, it just screws onto the stepper motor. Adding mounting points for a part cooling fan is something for the carriage, not the extruder, in my view. Can you point to a commercially available extruder with the mounting you are talking about? Maybe if I can see a real life example of what you are talking about I might have a better under standing of what you are wanting.
I can't place two titans directly next to each other as I need to access one side for the idler, and again the other side has a large protruding gear.
Re: E3D Aero, hot or not? March 26, 2017 02:37PM |
Re: E3D Aero, hot or not? March 26, 2017 05:59PM |
MechaBits
The more holes the better, yes it might add to the cost if you have to go 5 axis, but you can never have enough holes, thought there would be some to let the cogs & motor get some cooling, saves weight too.
the 20x20mmx3.2ish mm holes for mounting to a carriage or additional adapter plate(though others are different) Some spare lugs wherever they will fit, option to direct some of the air from cooler to part, and perhaps make the rest of it CNC'd seems a shame to have any plastic in it...I know helps reduce weight(though probably acts as a bit of an insulator) but a bulldog would last a lifetime, as will the cheap n nasty CNC'd one I'm using...though for a £5er perhaps nasty is too harsh, best value.
Re: E3D Aero, hot or not? March 26, 2017 10:36PM |
Re: E3D Aero, hot or not? March 27, 2017 01:44AM |
Re: E3D Aero, hot or not? March 27, 2017 09:00AM |
Re: E3D Aero, hot or not? March 27, 2017 09:16AM |
Origamib
I'm yet to find out the weight of the aero.
Re: E3D Aero, hot or not? March 28, 2017 08:57AM |
Re: E3D Aero, hot or not? March 29, 2017 09:27PM |
Re: E3D Aero, hot or not? April 08, 2017 03:14PM |
Re: E3D Aero, hot or not? April 09, 2017 07:55AM |
Re: E3D Aero, hot or not? April 09, 2017 08:29AM |
Re: E3D Aero, hot or not? April 21, 2017 08:46AM |
DjDemonD
Whilst it looks cool and has "shiny gadget" written all over it, isn't it just a mk8 extruder but with a 3:1 gearbox rather than direct? I'm going to try one so e3d are going to get my money....
