Ideal dual material setup? April 11, 2017 09:02AM |
Re: Ideal dual material setup? April 11, 2017 09:39AM |
Re: Ideal dual material setup? April 11, 2017 09:40AM |
Re: Ideal dual material setup? April 11, 2017 02:12PM |
Re: Ideal dual material setup? April 11, 2017 09:31PM |
Re: Ideal dual material setup? April 12, 2017 09:11AM |
Re: Ideal dual material setup? April 12, 2017 10:13AM |
Re: Ideal dual material setup? April 14, 2017 06:22AM |
dc42
The IDEX (dual X carriage solution) is probably the best solution, but also the most expensive. You don't need to get the nozzles exactly the same height unless you want to print 2 identical parts simultaneously using both hot ends, because each hot end can have its own Z offset. You can use bed probing and bed compensation.
There is quite a lot of discussion about this type of machine in the BigBox forum at e3d-online.
Re: Ideal dual material setup? April 14, 2017 07:33AM |
Re: Ideal dual material setup? April 14, 2017 01:45PM |
Re: Ideal dual material setup? April 14, 2017 02:05PM |
drmaestro
dc42
The alternative hot end mounting system that E3D is prototyping may help with this.
Do you have any link for that?
Re: Ideal dual material setup? April 15, 2017 09:58PM |
