Controllers advice and duetwifi question April 13, 2017 12:50PM |
Re: Controllers advice and duetwifi question April 13, 2017 01:00PM |
Re: Controllers advice and duetwifi question April 13, 2017 01:50PM |
Re: Controllers advice and duetwifi question April 13, 2017 02:18PM |
Re: Controllers advice and duetwifi question April 13, 2017 02:29PM |
Re: Controllers advice and duetwifi question April 13, 2017 02:31PM |
Re: Controllers advice and duetwifi question April 13, 2017 03:55PM |
Re: Controllers advice and duetwifi question April 13, 2017 04:23PM |
GroupB
IF you want to use Reprap Firmware ( same as duet) with a radds forget the LCD thing, it work only on marlin and repetier Not on Reprap Firmware.
Ill chose radds over any smoothie clone for sure again because of Reprap Firmware and support and the fact that the board is not a clone at all so QC is higher and Ill change the driver for raps128 or sd6168 since the tmc2660 are SPI controlled right ? I did not saw any driver stick made of tmc2660 yet and if they are some in the wild they may not be plug in play in driver socket. If you find some you are on your own with them since nobody use them as plug in driver so far.
For the shipping all website that sell radds also sell the raps128 or sd6128 and probably an original due.
Re: Controllers advice and duetwifi question April 13, 2017 04:42PM |
shortyski13
All good info, thanks! If I use my phone (galaxy S7 Edge), tablet, or laptop to control/send commands to the duetwifi, can I also do so mid-print, and say pause/start the printer mid-print, or would it be more of a set-it and wait until it's done or it's unplugged thing?
Re: Controllers advice and duetwifi question April 14, 2017 02:37AM |
Re: Controllers advice and duetwifi question April 14, 2017 11:03PM |
Re: Controllers advice and duetwifi question April 16, 2017 02:49PM |
Re: Controllers advice and duetwifi question April 16, 2017 04:23PM |
Re: Controllers advice and duetwifi question April 16, 2017 11:28PM |
