Does using bigger aluminium extrusions prevent ringing? April 18, 2017 02:23AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 05:06AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 06:26AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 07:58AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 08:01AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 11:18AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 12:08PM |
the_digital_dentist
Ringing isn't caused by the frame, it's caused by the moving mass interacting with the acceleration, belt stretch and motor springiness. Motor steps are defined by magnetic fields. They aren't hard mechanical stops, they behave like springs. When the motor is accelerating, the inertia of the moving mass causes it to respond late to what the motor is doing. If it's speeding up, as the motor tries to step, the magnetic spring loads, the belt stretches a little, then the mass starts to move. When the step has finished, the mass overshoots the final step position a little, then springs back. It wobbles back and forth a little and takes some finite time to settle.
This is a drawing made by my coreXY stage hooked up as a plotter when I was playing with it a little to check the acceleration and junction deviation settings.
The X axis is horizontal, but you can think of it as time, with t=0 at the far right. The Y axis vertical. The pen mounted in the extruder carriage moved up along Y then turned left to move along X. You can see that when it got to the corner, the high moving mass of the Y axis overshot the stopping point and sprung back the other way and wobbled a little until it settled onto the X line. That is ringing. It isn't because the pen was loose in the holder- it was mounted in a linear guide and there was zero wiggle in the bearing. If you stack it layer upon layer in a print, you get ripples in the walls of the print.
The printer has 40x40mm t-slot with 1/4" MIC6 plate. It is rock solid.
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 04:00PM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 04:55PM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 05:21PM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 06:19PM |
Re: Does using bigger aluminium extrusions prevent ringing? April 18, 2017 09:20PM |
Re: Does using bigger aluminium extrusions prevent ringing? April 19, 2017 07:42AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 19, 2017 09:52AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 19, 2017 10:02AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 19, 2017 11:21AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 19, 2017 12:05PM |
the_digital_dentist
It isn't just belts causing ringing- the motors themselves also contribute, possibly more than the belts.
Re: Does using bigger aluminium extrusions prevent ringing? April 21, 2017 02:19AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 21, 2017 04:06AM |
Re: Does using bigger aluminium extrusions prevent ringing? April 21, 2017 04:52AM |
drmaestro
So probably, with anything in plastic in this setup, we'll have ringing, as the plastic will invariably flex.
Re: Does using bigger aluminium extrusions prevent ringing? April 21, 2017 11:49AM |
leadinglights
drmaestro
Sort of, but only a partial truth. The thing that rings most is a bell - try printing one in PLA and you will find it clunks but does not ring. Plastic does flex, but it also damps vibration.
Proper structure is more important than what material. You have only to look at an ordinary printer (ink on paper, not 3D) to see how accurate and reproducible good engineering can make something. Take it apart so it is no longer a structure and all of the bits are downright floppy.
Mike
Re: Does using bigger aluminium extrusions prevent ringing? April 21, 2017 02:08PM |
Origamib
Considerably lighter gantries then what 3D printers typically deal with and made with injection moulded plastic parts that are dynamically stronger.... Cheap 3D printer have tried to emulate this and failed, so I feel like it's not a great comparison
Re: Does using bigger aluminium extrusions prevent ringing? May 08, 2017 03:09PM |
Re: Does using bigger aluminium extrusions prevent ringing? May 08, 2017 03:35PM |
Re: Does using bigger aluminium extrusions prevent ringing? May 09, 2017 02:02AM |
Re: Does using bigger aluminium extrusions prevent ringing? May 09, 2017 05:28PM |
