Hi all...
I am using 128*64 GLCD. On the LCD its 1% FAN PERCENTAGE but my controller FAN is FULL rotating (up to 255)... Pls tell me what can I do???
Here is pins.h
#define LED_PIN -1
#define FAN_PIN -1
#if FAN_PIN == 12 || FAN_PIN ==13
#define FAN_SOFT_PWM
#endif
#ifdef MELZI
#define LED_PIN 27 /* On some broken versions of the Sanguino libraries the pin definitions are wrong, which then needs LED_PIN as pin 28. But you better upgrade your Sanguino libraries! See #368. */
#define FAN_PIN 4 // Works for Panelolu2 too
#endif
#ifdef STB
#define FAN_PIN 4
// Uncomment this if you have the first generation (V1.10) of STBs board
#define LCD_PIN_BL 17 // LCD backlight LED
#endif
Using sanguinololu clone...
Here is config_adv.h
#define CONTROLLERFAN_PIN -1 //Pin used for the fan to cool controller (-1 to disable)
#define CONTROLLERFAN_SECS 60 //How many seconds, after all motors were disabled, the fan should run
#define CONTROLLERFAN_SPEED 255 // == full speed
// When first starting the main fan, run it at full speed for the
// given number of milliseconds. This gets the fan spinning reliably
// before setting a PWM value. (Does not work with software PWM for fan on Sanguinololu)
//#define FAN_KICKSTART_TIME 100
// Extruder cooling fans
// Configure fan pin outputs to automatically turn on/off when the associated
// extruder temperature is above/below EXTRUDER_AUTO_FAN_TEMPERATURE.
// Multiple extruders can be assigned to the same pin in which case
// the fan will turn on when any selected extruder is above the threshold.
#define EXTRUDER_0_AUTO_FAN_PIN -1
#define EXTRUDER_1_AUTO_FAN_PIN -1
#define EXTRUDER_2_AUTO_FAN_PIN -1
#define EXTRUDER_AUTO_FAN_TEMPERATURE 50
#define EXTRUDER_AUTO_FAN_SPEED 255 // == full speed
help asap....
