External Mosfet boards actually quite good! April 22, 2017 07:26AM |
Re: External Mosfet boards actually quite good! April 22, 2017 11:25AM |
Re: External Mosfet boards actually quite good! April 22, 2017 11:41AM |
Re: External Mosfet boards actually quite good! April 22, 2017 12:32PM |
Re: External Mosfet boards actually quite good! April 22, 2017 12:39PM |
Re: External Mosfet boards actually quite good! April 22, 2017 02:36PM |
Re: External Mosfet boards actually quite good! April 23, 2017 02:16AM |
Re: External Mosfet boards actually quite good! April 23, 2017 05:37AM |
Re: External Mosfet boards actually quite good! April 23, 2017 06:31AM |
dc42
Those boards are in effect un-encapsulated 5-terminal SSRs. Unlike normal 4-terminal SSRs, the gate voltage seen by the mosfet may be the full supply voltage if the board doesn't include components to limit it, and since many power MOSFETs have a gate voltage rating of 20V this could make operation on 24V inadvisable. The turn-off time may be quite slow, in which case they are likely to get hot if you use them with fast PWM.
Re: External Mosfet boards actually quite good! April 23, 2017 07:16AM |
Re: External Mosfet boards actually quite good! April 23, 2017 08:37AM |
Re: External Mosfet boards actually quite good! April 23, 2017 09:22AM |
Re: External Mosfet boards actually quite good! April 23, 2017 01:40PM |
Re: External Mosfet boards actually quite good! April 23, 2017 03:23PM |
Re: External Mosfet boards actually quite good! April 24, 2017 06:43AM |
Re: External Mosfet boards actually quite good! April 24, 2017 06:54AM |
Re: External Mosfet boards actually quite good! April 24, 2017 07:27AM |
Re: External Mosfet boards actually quite good! April 24, 2017 07:43AM |
Re: External Mosfet boards actually quite good! April 24, 2017 08:41AM |
Re: External Mosfet boards actually quite good! April 24, 2017 09:25AM |
Re: External Mosfet boards actually quite good! April 24, 2017 10:44PM |
dc42
Re: External Mosfet boards actually quite good! April 25, 2017 02:38AM |
Pheneeny
dc42
For the smaller one, the two outside solder terminals in the group of 5 are actually just posts securing the heat sink to the pcb. The mosfet only has 3 terminals connecting to the pcb. The number on the mosfet is HA210N06
Re: External Mosfet boards actually quite good! May 01, 2017 01:34PM |
Re: External Mosfet boards actually quite good! May 01, 2017 03:27PM |
Re: External Mosfet boards actually quite good! May 01, 2017 04:06PM |
newbob
I read that failed MOSFETs often short-circuit therefore two modules in series are needed to protect from runaway heater. I'm not sure however how well two in series would work in PWM mode.
Re: External Mosfet boards actually quite good! May 01, 2017 04:11PM |
It's not a good engineering practice to put two MOSFETs in series. Nobody does this even in Space/Military applications.Quote
newbob
Re: External Mosfet boards actually quite good! May 01, 2017 05:23PM |
DaveOB
newbob
This is a very interesting point, and I imagine this could be as much as problem for the Ramps on-board Mosfet, just as much as an external Mosfet.
So the simplest solution that I see is to have a basic relay in series before the Mosfet module, connected to a digital pin on Ramps.
In the starting gCode, set the digital pin High to enable power to the Mosfet.
At the end of the gCode, set the digital pin Low to disable power to the Mosfet.
Lastly, modify Marlin, so that in the event of an Max Bed Temperature condition, set the digital pin LOW, which removes any power going to the Mosfet.
Re: External Mosfet boards actually quite good! May 01, 2017 05:46PM |
newbob
Some relays have more than two NO leads, one set could be connected to hotbed MOSFET the other to hotend MOSFET board.
Re: External Mosfet boards actually quite good! May 01, 2017 07:12PM |
Re: External Mosfet boards actually quite good! June 06, 2020 12:15PM |
