Re: External Mosfet boards actually quite good! June 06, 2020 12:21PM |
Re: External Mosfet boards actually quite good! June 06, 2020 02:38PM |
...Quote
DjDemonD
So I was using a mechanical relay for my 24v heated bed on my corexy which has a second power supply.
So I bought one of these external mosfet boards and wired it up.
Re: External Mosfet boards actually quite good! June 06, 2020 02:51PM |
DaveOB
Thank You DjDemonD
Only just ordered the module so will take a while to arrive.
Thanks for the guidance and the ideas.
I suppose if the module does not work with a 5V signal, we could always beef up the signal with a transistor, or something like a 4N25 opto, controlled by 5V from the output pin, and connect the 12V PSU to the Mosfet Module Input.
Re: External Mosfet boards actually quite good! June 06, 2020 03:20PM |
