Good 30mm heatsink fans thumbs up
Posted by nebbian
May 07, 2017 10:13AM
I've been steadily working through eBay, buying 30mm x 10mm fans, putting them on my hotend, being disappointed, and buying another brand.
The problem with most of them is that they use sleeved bearings, which means that after a couple of months they start to wear out, and sound really bad for the first 30 seconds after a cold startup.
Now I've found one that seems to work really well, it's this one:
[www.ebay.com.au]
Gdt 12V 2Pin 3cm 30mm x 30mm x 10mm Ball Bearing Brushless DC Cooling Fan 3010B
Note that it's a ball bearing fan. It produces noticeably more airflow than the others as well, which means a cooler heatsink, so less chance of heat creep and subsequent jams when using PLA.
Very happy with this purchase smiling smiley
Re: Good 30mm heatsink fans thumbs up
May 07, 2017 11:37AM
Cool, might have a go at a 30mm part cooler, as other options get a little bulky, except air pump.
May 07, 2017 06:15PM
I find these indestructible and quiet. [uk.farnell.com] I'm not sure if they really run on non contact bearings but I haven't had one die yet.
If you want airflow but are quite deaf, these are the most insane fans I've ever used. [www.wildturbofan.com] they are practically drone propulsion units.
Link above fixed.
Edited 3 time(s). Last edit at 05/08/2017 04:16AM by DjDemonD.
Simon Khoury
Published:Inventions
May 14, 2017 12:26AM
I use Digi-Key for fan model selection, then shop around for a better price.
[www.digikey.com]
Best part, Digi-Key posts actual CFM and dB(A), not BS marketing jargon.
type "DC fan" in the search field, then drill down from there.
Edited 1 time(s). Last edit at 05/14/2017 12:27AM by prot0typ1cal.
