Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 07, 2017 06:13PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 08, 2017 06:25AM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 08, 2017 01:16PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 08, 2017 02:32PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 08, 2017 02:44PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 08, 2017 02:48PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 08, 2017 02:58PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 08, 2017 09:17PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 09, 2017 03:37AM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 09, 2017 04:30AM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 09, 2017 07:20AM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 09, 2017 09:39AM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. May 09, 2017 06:15PM |
PDBeal
There's always the concrete 3d printer. [www.youtube.com] Of course, he didn't print a house, but still I'm sure the application could be adapted.
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 31, 2017 08:24PM |
"Using cotton thread and a modified 3D printer nozzle of my own design I created high-strength composite parts with a flexural modulus (stiffness) over 14 times greater than unreinforced nylon with my low cost Prusa I3 printer."
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. August 01, 2017 02:24AM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. August 01, 2017 02:40AM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. August 12, 2017 02:47PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. August 13, 2017 02:30AM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. August 13, 2017 09:00AM |
There are other problems as well like how would you 3D print such large structures without warping when the plastic cools. This might just not work, and the approach to freely spray foam and mill it to shape might just be much easier.|
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 15, 2018 07:21PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 16, 2018 06:59AM |
Admin Registered: 18 years ago Posts: 14,148 |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 16, 2018 12:05PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 16, 2018 12:14PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 16, 2018 03:22PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 16, 2018 05:50PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 16, 2018 06:03PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 16, 2018 07:25PM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 17, 2018 10:47AM |
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 17, 2018 06:15PM |
VDX
... you can use "chips", sheets and prefabbed/shaped parts of this "compacted wood" for "puzzling" too - so a form/structure made of foam and after (or while puzzle-fabbing) coated with bullet-proof wood chips should be strong/rigid enough
Re: Extruder for foam? For 3D printing houses or boats or big things as a fiberglass / foam sandwich. July 17, 2018 07:06PM |
