Re: Precision Piezo Z-probe Now available. July 04, 2017 05:05PM |
Re: Precision Piezo Z-probe Now available. July 04, 2017 05:59PM |
Re: Precision Piezo Z-probe Now available. July 04, 2017 06:18PM |
Re: Precision Piezo Z-probe Now available. July 04, 2017 06:25PM |
frankvdh
Hi all,
I'm thinking ahead to mounting my Diamond hotend on my Delta printer, and hoping to save myself some design time... has anyone designed a Piezo20 mount for a Diamond hotend?
Frank
Re: Precision Piezo Z-probe Now available. July 05, 2017 01:38AM |
Re: Precision Piezo Z-probe Now available. July 05, 2017 02:42AM |
Re: Precision Piezo Z-probe Now available. July 05, 2017 09:15AM |
Re: Precision Piezo Z-probe Now available. July 08, 2017 01:11PM |
Re: Precision Piezo Z-probe Now available. July 08, 2017 02:38PM |
Re: Precision Piezo Z-probe Now available. July 09, 2017 09:40AM |
Re: Precision Piezo Z-probe Now available. July 11, 2017 06:28PM |
Re: Precision Piezo Z-probe Now available. July 11, 2017 06:40PM |
Re: Precision Piezo Z-probe Now available. July 11, 2017 06:44PM |
Hergonoway
So after 2 spool of filament, my first layer is always 0,1mm which is damn good.
The only drawback I have is the mount which let the hot end wobble, which lead to corner rings and other troubleshooting normally due to loosely frame. Maybe I'll try some spring and nuts to the 4 screws
Re: Precision Piezo Z-probe Now available. July 11, 2017 06:53PM |
Re: Precision Piezo Z-probe Now available. July 11, 2017 07:07PM |
Re: Precision Piezo Z-probe Now available. July 12, 2017 04:34PM |
Re: Precision Piezo Z-probe Now available. July 12, 2017 06:10PM |
Re: Precision Piezo Z-probe Now available. July 12, 2017 06:24PM |
Re: Precision Piezo Z-probe Now available. July 12, 2017 06:55PM |
Re: Precision Piezo Z-probe Now available. July 12, 2017 06:57PM |
Re: Precision Piezo Z-probe Now available. July 12, 2017 07:00PM |
Re: Precision Piezo Z-probe Now available. July 12, 2017 07:02PM |
Re: Precision Piezo Z-probe Now available. July 13, 2017 01:47AM |
DjDemonD
This is a question for Mike/Leadinglights he has tried a wide range of other sensing modalities including expensive accelerometers which he concluded were not as good as cheap piezo discs, requiring much more force to trigger.
But feel free to experiment.
When you say springs I think you conjure up the wrong image, the "spring" travel we use with piezo sensors is around 0.15mm of deflection, which is less than (possibly less than half of) a typical first layer height used in FDM printing, and is constant and therefore can be made allowance for - your z-offset.
There's no way around it, the very best z probe is direct electrical contact, and if I were printing onto aluminium (or other bare metal bed) I would use it, there's nothing simpler or more accurate. See this post [open-source-energy.org] for contact-contact which was exactly this, accurate to 1 micron with a 3 micron std deviation. It would be more accurate but Mike calculates that the controllers even Duet and the like need around 1-2ms to register a trigger. So if we could convince the makers of various print surfaces to make them electrically conductive then hey presto, we'd all have totally accurate bed probing, as long as we clean our nozzles, which we should be doing especially with piezo probes.
We managed in that test, 3 microns accuracy and around 10 microns standard deviation, so we're not far from the contact-contact result in terms of being able to position a nozzle to lay down a 200-300 micron first layer, and there are people out there who say if a z-probe can manage 50 microns accuracy its good enough for 3D printing. I'd disagree. Plus the microswitch z-probe is accurate but stow it and deploy it between each test and the result would be a lot less accurate and the std deviation would be quite large. With piezo as well as some other probing technologies the probe is fixed, most of these others require the probe to be offset though.
Re: Precision Piezo Z-probe Now available. July 13, 2017 03:46AM |
Re: Precision Piezo Z-probe Now available. July 13, 2017 06:32AM |
Re: Precision Piezo Z-probe Now available. July 13, 2017 09:05AM |
Re: Precision Piezo Z-probe Now available. July 13, 2017 09:49AM |
Re: Precision Piezo Z-probe Now available. July 13, 2017 02:23PM |
Re: Precision Piezo Z-probe Now available. July 13, 2017 03:37PM |
Re: Precision Piezo Z-probe Now available. July 13, 2017 06:59PM |
