Re: Precision Piezo Z-probe Now available. July 17, 2017 05:19PM |
Re: Precision Piezo Z-probe Now available. July 17, 2017 06:53PM |
Re: Precision Piezo Z-probe Now available. July 18, 2017 03:55AM |
Re: Precision Piezo Z-probe Now available. July 18, 2017 06:59AM |
Re: Precision Piezo Z-probe Now available. July 18, 2017 12:40PM |
Re: Precision Piezo Z-probe Now available. July 18, 2017 02:03PM |
Re: Precision Piezo Z-probe Now available. July 18, 2017 03:41PM |
Re: Precision Piezo Z-probe Now available. July 18, 2017 05:18PM |
Re: Precision Piezo Z-probe Now available. July 19, 2017 02:54AM |
Re: Precision Piezo Z-probe Now available. July 19, 2017 03:29AM |
Re: Precision Piezo Z-probe Now available. July 19, 2017 07:25AM |
Re: Precision Piezo Z-probe Now available. July 19, 2017 08:12AM |
Re: Precision Piezo Z-probe Now available. July 19, 2017 08:16AM |
Re: Precision Piezo Z-probe Now available. July 19, 2017 08:17AM |
Re: Precision Piezo Z-probe Now available. July 19, 2017 05:00PM |
Re: Precision Piezo Z-probe Now available. July 19, 2017 05:24PM |
Re: Precision Piezo Z-probe Now available. July 19, 2017 06:06PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 03:22AM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 04:21AM |
Suggy
Thanks Simon let me know how you get on. I was thinking along the same lines, (new clamp) maybe putting the piezo on top of the bed support and having something like a bolt in between the hbp and the piezo. Only problem I haven't figured out yet is how to make it adjustable
Re: Precision Piezo Z-probe Now available. July 20, 2017 04:54AM |
Suggy
Ok having trouble setting up the bed system. I have set the endstop to false and tried the polarity of the piezo both ways and I get the same trigger ether way it is. I have screwed the buffer until it just touches the piezo and then 1/4 turn more (without and bed adjustment nuts on) it needs an hard knock to make the led flash. When I screw the bed nuts down to adjust the be bed to something like level I don't get a trigger until the compression spring are nearly fully compressed.
Would like to get it running this way but if it too troublesome I will have to go down the extruder route.
All suggestions most welcome.
Ian
aka Suggy
Re: Precision Piezo Z-probe Now available. July 20, 2017 12:10PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 02:49PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 03:09PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 03:18PM |
There are no level nuts on when I took the photo. Yes done in place as they are glued to the bottom to the kapton tape. Will try with a different piezoQuote
leadinglights
Photo is nice and clear but I can't see the bed level adjusting nut - I assume that tests must have been done with this in place since this is the bit through which the pressure is transmitted to the piezo.
Try very lightly flexing the piezo - if this gets no response I think that the amplifier may have failed for some reason.
Mike
Re: Precision Piezo Z-probe Now available. July 20, 2017 04:11PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 04:31PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 04:36PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 04:55PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 05:12PM |
Re: Precision Piezo Z-probe Now available. July 20, 2017 05:25PM |
