Re: Precision Piezo Z-probe Now available. August 03, 2017 03:27PM |
Suggy
-core xyz Marlin 1.1.0 RC6
-300x200mm bed
-round holder fixed to bed carrage, piezo inside, lid then plunger (https://www.thingiverse.com/thing:2466725)
-4 point fixing around 40mm in from each end both back and front
-using DjDemonD 20mm underbed mounts
-3.6 Mohm VR1 (lowest I could get it to go) VR2 tuened until LED went out then about 1/8 turn
-z accel 3000 mm/s/s Jerk 0.4 mm/s (I think)
-probing speed ?mm/s travel ?mm/s (don't know where to find these)
Re: Precision Piezo Z-probe Now available. August 03, 2017 04:07PM |
Re: Precision Piezo Z-probe Now available. August 03, 2017 04:30PM |
Re: Precision Piezo Z-probe Now available. August 03, 2017 05:49PM |
Re: Precision Piezo Z-probe Now available. August 04, 2017 05:11AM |
Re: Precision Piezo Z-probe Now available. August 04, 2017 05:52AM |
Re: Precision Piezo Z-probe Now available. August 04, 2017 03:33PM |
Moriquendi
The problem with switches is that they're expensive and take up a lot of space on the board. I think that most people that are homebrewing their piezo system will have some soldering experience and the only people who would need to solder the jumper would be people who had gone from low sensitivity to high sensitivity (by cutting a trace) and then decided to go back to low sensitivity. A jumper is another possibility but again, there isn't much free space on the board, especially if I add mounting holes.
Idris
Re: Precision Piezo Z-probe Now available. August 04, 2017 03:40PM |
Re: Precision Piezo Z-probe Now available. August 04, 2017 04:34PM |
Re: Precision Piezo Z-probe Now available. August 04, 2017 05:05PM |
Re: Precision Piezo Z-probe Now available. August 04, 2017 05:10PM |
Re: Precision Piezo Z-probe Now available. August 04, 2017 05:25PM |
Re: Precision Piezo Z-probe Now available. August 04, 2017 05:28PM |
Re: Precision Piezo Z-probe Now available. August 05, 2017 05:33AM |
Re: Precision Piezo Z-probe Now available. August 05, 2017 05:35AM |
Re: Precision Piezo Z-probe Now available. August 05, 2017 05:42AM |
Re: Precision Piezo Z-probe Now available. August 05, 2017 05:47AM |
Re: Precision Piezo Z-probe Now available. August 05, 2017 06:31AM |
Re: Precision Piezo Z-probe Now available. August 06, 2017 12:56PM |
Re: Precision Piezo Z-probe Now available. August 06, 2017 12:59PM |
Re: Precision Piezo Z-probe Now available. August 06, 2017 02:24PM |
Re: Precision Piezo Z-probe Now available. August 06, 2017 02:32PM |
Re: Precision Piezo Z-probe Now available. August 07, 2017 04:21PM |
Re: Precision Piezo Z-probe Now available. August 07, 2017 09:49PM |
Re: Precision Piezo Z-probe Now available. August 08, 2017 01:57AM |
Re: Precision Piezo Z-probe Now available. August 08, 2017 02:28AM |
DjDemonD
They look good.
I'm not sure it makes any difference. In my latest bed mount design which has a thumb wheel plunger so I can use it to manually level, I installed the piezo with the ceramic face down as I figured I'd get less wear on the brass side of the disc from the rotating plunger, but I'm sure it would be quite minimal.
The piezo when used in squeeze-configuration can be either way around. If using it in bend configuration where you support it on the extremities and press in the middle polarity can come into play, but swapping the connector around is easy enough to do.
Re: Precision Piezo Z-probe Now available. August 08, 2017 02:45AM |
Alexander Mundy
Printed these mounts for underbed on my delta to replace the FSR's. Black parts are CF PETG and white are 40 hardness TPEE. Should I install the piezo's as shown or with the solid metal side against the plunger or does it matter? Don't have time tonight to install them and test, but will report back when I do.
Edit: mockup showed I designed the plungers a little too tall so have to reprint them.
look very much like what I have done the last two days. I try to put some pictures online the next days. did a first G33 yesterday with std dev 0.048 over the whole bed. Not bad - but I want more (or less?
Re: Precision Piezo Z-probe Now available. August 08, 2017 07:26AM |
Re: Precision Piezo Z-probe Now available. August 08, 2017 07:45AM |
Re: Precision Piezo Z-probe Now available. August 09, 2017 03:09AM |
