Re: Precision Piezo Z-probe Now available. August 09, 2017 03:50AM |
Re: Precision Piezo Z-probe Now available. August 09, 2017 04:25AM |
Re: Precision Piezo Z-probe Now available. August 09, 2017 04:29AM |
Re: Precision Piezo Z-probe Now available. August 09, 2017 04:43AM |
Re: Precision Piezo Z-probe Now available. August 09, 2017 01:42PM |
Re: Precision Piezo Z-probe Now available. August 09, 2017 05:02PM |
DjDemonD
I usually use -0.1 probe offset as technically the probe triggers below the bed. We are used to probes which trigger above the bed and have positive offsets.
The std deviation suggests your probing setup is close to optimal so for tighter levelling its probably worth looking at mechanics of the machine.
Re: Precision Piezo Z-probe Now available. August 09, 2017 06:57PM |
Re: Precision Piezo Z-probe Now available. August 10, 2017 01:27PM |
Re: Precision Piezo Z-probe Now available. August 10, 2017 01:42PM |
Re: Precision Piezo Z-probe Now available. August 10, 2017 02:55PM |
Re: Precision Piezo Z-probe Now available. August 10, 2017 03:26PM |
Re: Precision Piezo Z-probe Now available. August 10, 2017 03:28PM |
Re: Precision Piezo Z-probe Now available. August 12, 2017 08:10PM |
Re: Precision Piezo Z-probe Now available. August 13, 2017 05:02AM |
Re: Precision Piezo Z-probe Now available. August 13, 2017 06:42AM |
Re: Precision Piezo Z-probe Now available. August 13, 2017 11:35AM |
Re: Precision Piezo Z-probe Now available. August 15, 2017 07:03AM |
DjDemonD
Sounds like you are making progress. 0.02mm deviation is not bad.
Keep us posted.
Re: Precision Piezo Z-probe Now available. August 15, 2017 10:01AM |
) and do the M48 repeatability test. The accuracy/deviation you get now is what your machine is capable of mechanically. The difference is the contribution of the piezo probe. If they are the same then the probe is performing as well as your machine is able to mechanically. Its a good way to control for the machine's capabilities when testing.Try lowering your probing speed to a very low value, see what difference it makes.|
Re: Precision Piezo Z-probe Now available. August 15, 2017 01:18PM |
Re: Precision Piezo Z-probe Now available. August 17, 2017 01:10PM |
Re: Precision Piezo Z-probe Now available. August 17, 2017 01:20PM |
Re: Precision Piezo Z-probe Now available. August 17, 2017 01:22PM |
Re: Precision Piezo Z-probe Now available. August 17, 2017 01:44PM |
If it works good I want this on my corexy also. |
Re: Precision Piezo Z-probe Now available. August 17, 2017 03:35PM |
Re: Precision Piezo Z-probe Now available. August 17, 2017 04:22PM |
Re: Precision Piezo Z-probe Now available. August 17, 2017 04:38PM |
Re: Precision Piezo Z-probe Now available. August 17, 2017 06:06PM |
Re: Precision Piezo Z-probe Now available. August 17, 2017 08:16PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 05:53AM |
The one with 50mV scale is me tapping it gently. The one with 1Volt scale is moving the mount ALOT. I see that with the same sensor they manage to get 8-10V peak in another thread but no chance getting that here. Is it my piezo that is broken or what? Now I can't get it triggering properly at all so something is off
Re: Precision Piezo Z-probe Now available. August 18, 2017 06:09AM |
