Re: Precision Piezo Z-probe Now available. August 18, 2017 06:29AM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 06:46AM |
Moriquendi
I'm going to need some more information to be able to help you properly.
What signal are you probing?
Where is your ground probe connected
How are you measuring the resistance of VR1
VR1 shouldn't need any adjustment, it's mostly there to account for people using different size disks, it's normally the last thing that needs adjusting. VR1 and VR2 have only about 270deg of travel but there are no physical stops, if you go outside this range they go open circuit which with VR1 causes very high sensitivity. Potentiometers this size are delicate, be gentle when adjusting them.
My suggestion is that you set VR1 to the middle of it's travel (blue spot pointing away from the connector), re-tune VR2 and try it with a bare piezo (not stuck to anything).
Be aware that you need to use an insulated tool when testing the piezo, if you touch it with your finger the circuit is sensitive enough to be triggered by the capacitance of your body.
Idris
Re: Precision Piezo Z-probe Now available. August 18, 2017 06:49AM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 06:58AM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 07:00AM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 07:35AM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 07:53AM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 10:26AM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 11:17AM |
Moriquendi
First thing to check would be that the centre wire is still connected to the piezo, that solder joint in particularly delicate. If you've bent the disk too far you may have cracked the ceramic or broken it off the brass, that would show up as faint lines on the silver surface. Other than that there's really very little that can go wrong with the disk itself. Check for continuity between the connector and the piezo (brass backing to connector black, silver centre to connector red).
Idris
Re: Precision Piezo Z-probe Now available. August 18, 2017 11:36AM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 12:37PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 12:39PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 01:06PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 01:26PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 01:28PM |
DjDemonD
If you want I will send you a spare board to see if its the board, if it is send the old one back, if it isn't then either keep it and I'll invoice you or send it back.
Re: Precision Piezo Z-probe Now available. August 18, 2017 01:41PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 02:05PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 02:18PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 02:30PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 02:34PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 02:41PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 02:52PM |
DjDemonD
Sounds ridiculously stupid but make sure the piezo polarity is correct, or just try flipping it and a quick retune and try again. This is my go to solution if I get sloppy "delayed" triggering.
Re: Precision Piezo Z-probe Now available. August 18, 2017 03:13PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 04:07PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 04:09PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 05:01PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 05:57PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 06:03PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 06:06PM |
Re: Precision Piezo Z-probe Now available. August 18, 2017 06:15PM |
