Re: Precision Piezo Z-probe Now available. September 11, 2017 11:43AM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:17PM |
Moriquendi
Sounds like a config issue. I've not used a Cartesian machine before but I have been using smoothie for a while.
It looks to me like you have pin 1.29 as both the gamma min endstop and your z-probe, is this normal for a cartesian machine? With a delta you use three endstops and a seperate z-probe
Idris
Edit: scratch that, you've got the pull up enabled on the z-probe pin ( zprobe.probe_pin 1.29^) this means that the smoothieboard is pulling pin 1.29 high then reading it, finding a high voltage, and assuming that the probe is triggered. Remove the ^ from your z-probe (and gamma max) pin definitions and you should be fine.
SENDING:G1 X150 Y150 >>> G28 SENDING:G28 >>> G32 SENDING:G32 Rectangular Grid Probe... Finding bed failed, check the initial height setting Probe failed to complete, check the initial probe height and/or initial_height settings
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:33PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:40PM |
Moriquendi
What happens if you move the z-axis up 100-150mm then do a G30? As the z-axis is moving, tap the nozzle, it should register and reverse the z-movement.
Idris
G28 G1 X150 Y150 G1 Z150 G30
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:42PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:43PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:44PM |
X_min:0 Y_min:1 Z_min:0 pins- (X)P1.24:0 (Y)P1.26:1 (Z)P1.29:0 Probe: 0 ok
alpha_min -2 # This gets loaded as the current position after homing when home_to_min is set
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:45PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:47PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:50PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:52PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 12:53PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 01:06PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 01:13PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 01:49PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 06:35PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 06:47PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 09:21PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 10:44PM |
Re: Precision Piezo Z-probe Now available. September 11, 2017 11:01PM |
Re: Precision Piezo Z-probe Now available. September 12, 2017 03:21AM |
Re: Precision Piezo Z-probe Now available. September 12, 2017 04:06AM |
Re: Precision Piezo Z-probe Now available. September 12, 2017 05:04AM |
Re: Precision Piezo Z-probe Now available. September 12, 2017 05:13AM |
Re: Precision Piezo Z-probe Now available. September 12, 2017 05:32AM |
Re: Precision Piezo Z-probe Now available. September 12, 2017 05:52AM |
M140 S[bed0_temperature] ; Set bed temperature no wait M104 S[extruder0_temperature] ; Set hotend temperature no wait G91 ; Relative distances G1 Z5 ; Move Z up to clear any obstructions G90 ; Absolute distances G28 XY ; Home X and Y axes G1 X150 Y150 F6000 ; Go to the center of the bed G28 Z ; Home the Z axis G1 X310 Y2 F6000 ; Go to the front right corner of the bed M400 ; Wait for current move to finish G1 Z-0.2 F1200 ; Position nozzle below the plane of the bed surface M190 S[bed0_temperature] ; Set bed temperature and wait M109 S[extruder0_temperature] ; Set hotend temperature and wait G92 E0 ; Reset extrusion distance G1 E10 F300 ; Extrude 10mm of filament M400 ; Wait for current move to finish G92 E0 ; Reset extrusion distance G1 X240 F1200 ; Wipe nozzle M400 ; Wait for current move to finish G1 Z[first_layer_height] F1200 ;
Re: Precision Piezo Z-probe Now available. September 12, 2017 06:57AM |
Re: Precision Piezo Z-probe Now available. September 12, 2017 07:17AM |
klcjr89
I am not sure what to change in my start script.
