Re: Precision Piezo Z-probe Now available. October 10, 2017 10:29AM |
totalitarian
My bed is sat on 4 corner springs. Will this work with the under bed setup? I only ask because the PCB only has 3 piezo inputs...............
Also, could we have a drilled piezo disc sandwiched between the the spring and the carriage or does it need a more elegant solution
Re: Precision Piezo Z-probe Now available. October 10, 2017 11:05AM |
Re: Precision Piezo Z-probe Now available. October 10, 2017 11:28AM |
Re: Precision Piezo Z-probe Now available. October 10, 2017 12:07PM |
Re: Precision Piezo Z-probe Now available. October 10, 2017 12:17PM |
Re: Precision Piezo Z-probe Now available. October 11, 2017 03:59AM |
// coarse Endstop Settings #define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #if DISABLED(ENDSTOPPULLUPS) // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined //#define ENDSTOPPULLUP_XMAX //#define ENDSTOPPULLUP_YMAX //#define ENDSTOPPULLUP_ZMAX //#define ENDSTOPPULLUP_XMIN //#define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN //#define ENDSTOPPULLUP_ZMIN_PROBE #endif // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the probe.
// coarse Endstop Settings //#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors #if DISABLED(ENDSTOPPULLUPS) // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined #define ENDSTOPPULLUP_XMAX #define ENDSTOPPULLUP_YMAX #define ENDSTOPPULLUP_ZMAX #define ENDSTOPPULLUP_XMIN #define ENDSTOPPULLUP_YMIN //#define ENDSTOPPULLUP_ZMIN //#define ENDSTOPPULLUP_ZMIN_PROBE #endif // Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. #define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the probe.
Re: Precision Piezo Z-probe Now available. October 11, 2017 04:01AM |
Re: Precision Piezo Z-probe Now available. October 11, 2017 04:05AM |
Re: Precision Piezo Z-probe Now available. October 11, 2017 04:48AM |
Re: Precision Piezo Z-probe Now available. October 11, 2017 04:51AM |
leadinglights
totalitarian
You can work with 4 corner springs But, and it is a big but, with 4 mounts the forces on the springs will mostly be trying to bend the plate, or bend the carriage and one of the adjusting nuts will likely be looser than the others. If you using sensors which have a very low compliance this is likely to make the slightly loose one too sensitive. Although the design may force you to have four mountings it is something to be avoided - like smoking or running with scissors - three mounts is much better.
Like this?
[attachment 98709 Simplex_Annotated.png]
This arrangement works quite well with just a little caveat: Make sure that the drilled hole does not have burrs around the edge as this will make for some strange triggering
Mike
Re: Precision Piezo Z-probe Now available. October 11, 2017 05:12AM |
totalitarian
Thanks, 4 is what i've been given so i'll have to live with it for now. Yes that design was exactly what I was planning to do. Do you have a link to the pressure pads? Also what size piezo would you suggest?
Re: Precision Piezo Z-probe Now available. October 11, 2017 05:24AM |
Re: Precision Piezo Z-probe Now available. October 11, 2017 10:57AM |
Re: Precision Piezo Z-probe Now available. October 13, 2017 02:54PM |
Re: Precision Piezo Z-probe Now available. October 13, 2017 03:11PM |
Re: Precision Piezo Z-probe Now available. October 13, 2017 03:14PM |
DjDemonD
I have a titan/aero bracket design for piezo its here:
[www.thingiverse.com]
And a different idea which is very much a beta, I have one on my corexy its working okay:
Re: Precision Piezo Z-probe Now available. October 13, 2017 03:15PM |
DjDemonD
Re: Precision Piezo Z-probe Now available. October 13, 2017 03:31PM |
Re: Precision Piezo Z-probe Now available. October 13, 2017 05:00PM |
coredump
DjDemonD
where did you add that? On the back of the motor? It's not really possible in my case because there's nowhere to attach unless I move the motor to the front, what I am afraid of unbalancing stuff.
I've been doing that, but still not a lot out there.
Re: Precision Piezo Z-probe Now available. October 14, 2017 01:19PM |
Re: Precision Piezo Z-probe Now available. October 14, 2017 02:15PM |
Re: Precision Piezo Z-probe Now available. October 14, 2017 02:32PM |
No, I'm using a Bowden setup on Tronxy X5S (cheap corexy from china) mount is similar to a CR10. It's probably more straightforward to just get a 20mm sensor and use the groovemount, but I'm a sadist.
Re: Precision Piezo Z-probe Now available. October 14, 2017 02:36PM |
Re: Precision Piezo Z-probe Now available. October 14, 2017 02:46PM |
Re: Precision Piezo Z-probe Now available. October 14, 2017 03:05PM |
Re: Precision Piezo Z-probe Now available. October 14, 2017 03:42PM |
Re: Precision Piezo Z-probe Now available. October 14, 2017 04:19PM |
Re: Precision Piezo Z-probe Now available. October 14, 2017 09:11PM |
Re: Precision Piezo Z-probe Now available. October 15, 2017 03:04AM |
Re: Precision Piezo Z-probe Now available. October 15, 2017 03:34AM |
