Re: Precision Piezo Z-probe Now available. April 02, 2018 04:00AM |
hardy1234
Hi guys, what is the best position for the piezo?
I'm not sure. Since I have a moving bed y axis.
I have this printer.
[www.3d-druckerforum.de]
And this holder as dual
[www.thingiverse.com]
Im not so good in redesign I hope you can help me thanks.
I had already tried FSR sensors in stamps but these have lasted since I had them on the 3 stops from the moving bed.
That was not good
I hope this solution is a success
Greetings Hardy
Re: Precision Piezo Z-probe Now available. April 02, 2018 07:16AM |
Re: Precision Piezo Z-probe Now available. April 02, 2018 07:42AM |
Re: Precision Piezo Z-probe Now available. April 02, 2018 08:48AM |
Re: Precision Piezo Z-probe Now available. April 02, 2018 09:21AM |
Re: Precision Piezo Z-probe Now available. April 02, 2018 10:00AM |
Re: Precision Piezo Z-probe Now available. April 02, 2018 11:51AM |
Re: Precision Piezo Z-probe Now available. April 02, 2018 12:37PM |
Re: Precision Piezo Z-probe Now available. April 02, 2018 12:41PM |
tekkydave
Hi. Does the Orion use 2 separate piezo discs as opposed to a drilled one?
Re: Precision Piezo Z-probe Now available. April 02, 2018 01:55PM |
DjDemonD
tekkydave
The Orion uses Piezos soldered to a pcb. The pcb has a hole in it.
Re: Precision Piezo Z-probe Now available. April 02, 2018 01:56PM |
Re: Precision Piezo Z-probe Now available. April 02, 2018 02:31PM |
tekkydave
DjDemonD
tekkydave
So the filament isn't going through a hole in a piezo. I seem to be having issues with my PP20 where the filament is catching on the sharp edge of the drilled hole. Could be a good reason to upgrade to the Orion
Re: Precision Piezo Z-probe Now available. April 02, 2018 02:41PM |
DjDemonD
Is it a 3mm filament system, if it is thats an issue that might solved by taking a needle file to the drilled metal edge? If it's 1.75mm then use a short piece of bowden tube through the unit just as a filament guide, this is good practice not to have any 1.75mm filament unconstrained especially with flexible materials.
Re: Precision Piezo Z-probe Now available. April 03, 2018 06:30AM |
tekkydave
DjDemonD
Yes, 3mm. Groovemount on Titan. I have to take it all apart tomorrow to see what's going on. I'll see if the sharp edge can be taken off. Thanks.
[attachment 103953 IMG_20171211_112204.jpg]
Re: Precision Piezo Z-probe Now available. April 03, 2018 06:35AM |
Re: Precision Piezo Z-probe Now available. April 03, 2018 06:41AM |
DjDemonD
I think I've heard about it happening in the past perhaps once. And with 3mm yes. Don't worry if there is a little ceramic missing, in terms of function it makes almost no difference.
Re: Precision Piezo Z-probe Now available. April 03, 2018 07:20AM |
Re: Precision Piezo Z-probe Now available. April 03, 2018 07:45AM |
Thats a good idea. I bought the piezo pre-drilled as I didn't fancy drilling it myself. However, I have an idea for a slight modification to the groovemount plastic parts for 3mm use - watch this spaceQuote
Moriquendi
Somebody had the same problem as you and I think he solved it by putting kapton tape over the piezo before drilling, I wonder whether you could do the same thing but poke a hole in the tape to put the filament through.
Idris
Re: Precision Piezo Z-probe Now available. April 03, 2018 07:54AM |
Re: Precision Piezo Z-probe Now available. April 03, 2018 08:46AM |
Re: Precision Piezo Z-probe Now available. April 03, 2018 09:37AM |
Re: Precision Piezo Z-probe Now available. April 04, 2018 05:32PM |
Re: Precision Piezo Z-probe Now available. April 04, 2018 05:51PM |
Re: Precision Piezo Z-probe Now available. April 04, 2018 06:06PM |
Re: Precision Piezo Z-probe Now available. April 07, 2018 11:56AM |
Re: Precision Piezo Z-probe Now available. April 08, 2018 08:56AM |
Re: Precision Piezo Z-probe Now available. April 08, 2018 09:36AM |
Re: Precision Piezo Z-probe Now available. April 08, 2018 09:56AM |
Re: Precision Piezo Z-probe Now available. April 08, 2018 12:57PM |
Re: Precision Piezo Z-probe Now available. April 08, 2018 02:47PM |
