Re: Precision Piezo Z-probe Now available. April 18, 2018 08:11PM |
AlmostNeverAgain
Hi Simon and Idris,
Building a custom cartesian printer, I was about to buy your piezo20, but I see your multi ceram Orion, and I don't know the advantage buying this one instead of that one.
Could you please clarify by comparing both ?
On the cartesian side, the Z travel is more restricted than of a delta, and every Z centimeter counts ! So, your Z probe integration into my design is really critical,
trying to get the exact dimensioning of your module, based on your published STLs.
It is a little a nightmare to find the latest version of your STLs, there is no PDF blueprint, no dimensional description.
Familar with CAD conversion, I managed to skin your STL with a STEP envelope, and i am very surprised to see how bad is your part design!
One example, I splitted your STL into the 4 parts, trying to re-assemble them... the holes patterns of the 3 screw-able parts are not exactly the same, impossible to CAD-align. the holes axis are not perfectly perpendicular to the side, impossible to fully constraint.
To sum it up, I think that you should publish the exact and latest dimensional data, either by providing the STEP/IGES CAD files, or front/side/top schematics.
Eventually, I would be more than happy to contribute by designing quality CAD files, of course.
Thanks in advance.
EDIT:
- The probe20 assembly based on the parts draft from the STL measures 24mm approx between upper/lower groovemounts. (2mm gap between piezo plate and lower part).
- Assembling the probe20 to a BMG extruder seems not possible, the upper groove entering too much into the BMG extruder body.
Re: Precision Piezo Z-probe Now available. April 19, 2018 04:27AM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 04:44AM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 04:53AM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 05:07AM |
o_lampe
Leonardo DaVinci did the same and added some errors in his drawings to keep them from being copied by spies
Re: Precision Piezo Z-probe Now available. April 19, 2018 08:46AM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 09:16AM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 10:12AM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 11:33AM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 02:04PM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 03:00PM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 03:25PM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 05:14PM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 05:37PM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 05:57PM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 06:09PM |
Re: Precision Piezo Z-probe Now available. April 19, 2018 09:59PM |
Moriquendi
There's no problem with signal available from the piezos, in fact we have to take precautions to prevent a hard trigger from causing a damaging voltage spike.
Temperature decreases the output of the piezo disks, practically what that means is that if you're using a heated chamber you have to tune at the same temperature you probe at.
Idris
Re: Precision Piezo Z-probe Now available. April 20, 2018 02:29AM |
Re: Precision Piezo Z-probe Now available. April 20, 2018 03:40AM |
AlmostNeverAgain
1) Chinese are writing from right to left, as Leornardo did, to hide written words, but not for the same reasons !
2) Just one question: If a frame-based (bracket, hinge,...) solution would allow to trigger the endstop when PCB/Piezos compression is released, ..
Re: Precision Piezo Z-probe Now available. April 20, 2018 03:58AM |
Re: Precision Piezo Z-probe Now available. April 20, 2018 05:06AM |
Re: Precision Piezo Z-probe Now available. April 20, 2018 05:10AM |
Re: Precision Piezo Z-probe Now available. April 20, 2018 07:29AM |
o_lampe
Temperature compensation and noise reduction goes hand_in_hand.
Re: Precision Piezo Z-probe Now available. April 20, 2018 09:02AM |
Re: Precision Piezo Z-probe Now available. April 20, 2018 09:13AM |
Re: Precision Piezo Z-probe Now available. April 21, 2018 01:42AM |
I think what o_Lampe is getting at is that if you have good enough noise cancellation you can set the circuit to be so sensitive that even with the decreased signal at 80c you're still getting reliable triggers without getting spurious triggers at lower temps.
Re: Precision Piezo Z-probe Now available. April 21, 2018 11:32AM |
Re: Precision Piezo Z-probe Now available. April 21, 2018 12:17PM |
Re: Precision Piezo Z-probe Now available. April 22, 2018 01:57AM |
Chowa
...and the sensitivity is such that walking by on a wooden floor causes triggers.
Re: Precision Piezo Z-probe Now available. April 22, 2018 03:45AM |
