V2 board will not respond June 06, 2018 04:32PM |
Re: Precision Piezo Z-probe Now available. June 06, 2018 05:53PM |
Re: Precision Piezo Z-probe Now available. June 06, 2018 07:28PM |
Re: Precision Piezo Z-probe Now available. June 07, 2018 03:34AM |
Re: Precision Piezo Z-probe Now available. June 11, 2018 09:36PM |
Re: Precision Piezo Z-probe Now available. June 12, 2018 11:13AM |
Re: Precision Piezo Z-probe Now available. June 12, 2018 12:10PM |
Re: Precision Piezo Z-probe Now available. June 12, 2018 02:53PM |
Re: Precision Piezo Z-probe Now available. June 12, 2018 06:32PM |
Re: Precision Piezo Z-probe Now available. June 18, 2018 01:01PM |
Re: Precision Piezo Z-probe Now available. June 18, 2018 01:19PM |
Re: Precision Piezo Z-probe Now available. June 19, 2018 01:41AM |
Re: Precision Piezo Z-probe Now available. June 19, 2018 08:57AM |
Re: Precision Piezo Z-probe Now available. June 20, 2018 01:39AM |
Moriquendi
Valentin,
Try loosening the four assembly bolts slightly, start with 0.5 turns per bolt and test sensitivity again, you may need to do this a couple of times but in some setups this can make a big difference.
Another possibility is that you have turned VR1 too far and need to turn it back by 180 degrees before retuning.
Do you have "pause before probing" enbled?
Re: Precision Piezo Z-probe Now available. June 20, 2018 10:25AM |
Re: Precision Piezo Z-probe Now available. June 20, 2018 04:19PM |
Re: Precision Piezo Z-probe Now available. June 22, 2018 03:33AM |
Moriquendi
Let me know how that goes.
One thing to check, did you replace the wiring when you installed the Orion? The pinout is different from the V2 boards.
Idris
Re: Precision Piezo Z-probe Now available. June 22, 2018 05:05AM |
Re: Precision Piezo Z-probe Now available. June 26, 2018 03:50PM |
Re: Precision Piezo Z-probe Now available. June 27, 2018 02:35AM |
Re: Precision Piezo Z-probe Now available. June 27, 2018 04:24AM |
Re: Precision Piezo Z-probe Now available. June 27, 2018 04:42AM |
Re: Precision Piezo Z-probe Now available. June 27, 2018 09:47PM |
Moriquendi
There's no advantage to pausing unless you are probing in Z, smoothieware doesn't react to triggers unless it is probing. Furthermore, unless you implement a delay within the G32 probing cycle you're still going to be probing with vibrations for all probe events except the first one. You need to include;
zprobe.dwell_before_probing 0.5
into your config file, this means that smoothie will wait for 0.5 seconds between any xy movement and a z-probe event.
Re: Precision Piezo Z-probe Now available. June 28, 2018 05:34AM |
Re: Precision Piezo Z-probe Now available. June 30, 2018 08:24AM |
Re: Precision Piezo Z-probe Now available. June 30, 2018 08:55AM |
Re: Precision Piezo Z-probe Now available. June 30, 2018 11:27AM |
Re: Precision Piezo Z-probe Now available. June 30, 2018 04:53PM |
Re: Precision Piezo Z-probe Now available. June 30, 2018 05:24PM |
Re: Precision Piezo Z-probe Now available. July 02, 2018 02:42PM |
