Re: Precision Piezo Z-probe Now available. May 14, 2019 10:21AM |
Re: Precision Piezo Z-probe Now available. May 15, 2019 06:44AM |
Re: Precision Piezo Z-probe Now available. May 15, 2019 01:11PM |
Re: Precision Piezo Z-probe Now available. May 26, 2019 09:14PM |
Re: Precision Piezo Z-probe Now available. May 26, 2019 10:06PM |
Re: Precision Piezo Z-probe Now available. May 27, 2019 04:52AM |
Re: Precision Piezo Z-probe Now available. May 29, 2019 02:23PM |
Re: Precision Piezo Z-probe Now available. May 29, 2019 04:38PM |
Re: Precision Piezo Z-probe Now available. June 02, 2019 02:49PM |
Moriquendi
Is that deviation across the bed or deviation in one place? What height do you probe from?
Idris
Re: Precision Piezo Z-probe Now available. June 02, 2019 10:16PM |
Re: Precision Piezo Z-probe Now available. June 03, 2019 12:14PM |
ruggb
Marlin does not have a Z_PROBE_HEIGHT parameter so I don't know how that factors in.
Re: Precision Piezo Z-probe Now available. June 03, 2019 03:07PM |
Re: Precision Piezo Z-probe Now available. June 03, 2019 03:43PM |
Re: Precision Piezo Z-probe Now available. June 03, 2019 03:53PM |
Re: Precision Piezo Z-probe Now available. June 03, 2019 05:03PM |
ruggb
that is the problem with changes.
ruggb
if u are touching your board and it triggers, I guess the circuit is working, assuming your touch isn't hitting the circuits..
ruggb
What happens when you touch the nozzle?
If it doesn't work or takes too much of a touch then it sounds like your mechanism is a little too tight.
If it responds with a reasonable touch, the homing speed might be a little too slow. .
Re: Precision Piezo Z-probe Now available. June 03, 2019 06:21PM |
Re: Precision Piezo Z-probe Now available. June 05, 2019 12:29AM |
Re: Precision Piezo Z-probe Now available. June 05, 2019 03:12AM |
Admin Registered: 11 years ago Posts: 3,096 |
jens53
Short of reading 63 pages of messages ... quick question please.
My old printer used a z endstop in addition to a BLtouch. The BLtouch was only used to map the bed. In the new printer there is no separate z endstop.
When a print is started, the hot end normally heats up and then the printhead is homed. Will any bits hanging off the nozzle affect where the printer thinks that z 0 is ? Is there a special procedure for the Orion sensor to establish z 0 ? I understand that for bed mapping the nozzle is heated up to below oozing temperature, the nozzle is cleaned and then the surface is mapped but it would be a real PITA to have to do that before every print.
Re: Precision Piezo Z-probe Now available. June 05, 2019 10:36AM |
jens53
Re: Precision Piezo Z-probe Now available. June 05, 2019 11:24AM |
Re: Precision Piezo Z-probe Now available. June 05, 2019 12:27PM |
jens53
Thanks for the info. I do retract (1.5 mm) at the end of a print but despite that, I get several inches of ooze. Usually about an inch between finishing the print and cool-down. I get another inch or two on warm-up for a new print. I use PETG, hence the filament drooling. I also print a skirt to prime. My printer is also a Bowden tube printer.
Seems like I need to keep my procedures exactly as they are.
Thanks !
Re: Precision Piezo Z-probe Now available. June 05, 2019 12:35PM |
Re: Precision Piezo Z-probe Now available. June 05, 2019 04:01PM |
Re: Precision Piezo Z-probe Now available. June 05, 2019 06:44PM |
sinned
umm, why not just READ the installation instructions? it's all covered in there with pretty pictures too... just saying
don't heat more than 130 for probing. excessive retracts are not necessary
Re: Precision Piezo Z-probe Now available. June 06, 2019 12:16AM |
Re: Precision Piezo Z-probe Now available. June 06, 2019 06:44AM |
jens53
In any event, I did not see anything in the instructions about normal homing of the print head. Do you go to 130 every time you start a print job, wait until the printhead is at that temperature, clean the printhead then home then stop to heat the printhead some more and then proceed to do the print? This would not be a satisfactory way to do things as a lot of times a print is started remotely.
Re: Precision Piezo Z-probe Now available. June 13, 2019 08:11AM |
Re: Precision Piezo Z-probe Now available. June 13, 2019 08:35AM |
Amegatek
Anyone using the Anycubic Mega-S with the Orion? If so, where did you make the connection to the printer?
Re: Precision Piezo Z-probe Now available. June 17, 2019 02:48PM |
Re: Precision Piezo Z-probe Now available. June 17, 2019 04:52PM |
