Re: Precision Piezo Z-probe Now available. August 21, 2019 02:43AM |
Re: Precision Piezo Z-probe Now available. August 21, 2019 03:40AM |
Re: Precision Piezo Z-probe Now available. August 21, 2019 10:34AM |
Re: Precision Piezo Z-probe Now available. August 21, 2019 04:37PM |
Re: Precision Piezo Z-probe Now available. August 21, 2019 04:55PM |
Re: Precision Piezo Z-probe Now available. August 26, 2019 12:49PM |
Re: Precision Piezo Z-probe Now available. August 26, 2019 01:17PM |
Re: Precision Piezo Z-probe Now available. August 26, 2019 01:33PM |
Moriquendi
What do you mean when you say inverted the sense direction?
The at rest reading will vary with temperature. I suspect that something is still off with your mechanical design, you should have a wider range of tuneability.
Idris
Re: Precision Piezo Z-probe Now available. August 26, 2019 06:50PM |
; Z-Probe M574 Z1 S2 ; Set endstops controlled by probe M558 P8 I1 R0.4 H2 F600 T6000 ; Suggestions from Idris at PP, change to digital and more senstive setting, reduce travel and speed from ; set Z probe to digital, NO switch, 2mm dive height, 0.4 sec probe recovery time ; Z probe speed 10 mm/sec XY travel 100mm/min probe travel speed and set as Z endstop ; was ; M558 P5 I1 R0.4 H5 F600 T6000 ; Set Z probe type to effector and the dive height + speeds ; G31 P500 X0 Y0 Z-0.4 ; Set Z probe trigger value, offset and trigger height ; G31 Pnnn Xnnn Ynnn Znnn Cnnn Snnn ; Pnnn Trigger value ; Xnnn Probe X offset1 ; Ynnn Probe Y offset1 ; Znnn Trigger Z height ; Cnnn Temperature coefficient ; Snnn Calibration temperature 2 ; Tnnn Z probe type to which these parameters apply, defaults to the current ; Z probe type as defined by M558 P parameter M557 X5:285 Y5:285 S70 ; Define mesh grid
Re: Precision Piezo Z-probe Now available. August 26, 2019 06:59PM |
Re: Precision Piezo Z-probe Now available. August 26, 2019 07:05PM |
Re: Precision Piezo Z-probe Now available. August 27, 2019 10:20AM |
Re: Precision Piezo Z-probe Now available. September 18, 2019 05:32PM |
Re: Precision Piezo Z-probe Now available. September 18, 2019 05:53PM |
Re: Precision Piezo Z-probe Now available. September 19, 2019 02:30AM |
ryan99alero
.... They vary from .01 - .022 mm. I thought from what I read on the sales slick they were suppose to be around .0003 for there deviation. .....
Re: Precision Piezo Z-probe Now available. September 19, 2019 06:26AM |
Re: Precision Piezo Z-probe Now available. September 19, 2019 11:07AM |
ryan99alero
The calculated the deviation across all readings at each location. They vary from .01 - .022 mm. I thought from what I read on the sales slick they were suppose to be around .0003 for there deviation
Re: Precision Piezo Z-probe Now available. September 19, 2019 11:47AM |
Re: Precision Piezo Z-probe Now available. September 19, 2019 01:15PM |
Re: Precision Piezo Z-probe Now available. September 20, 2019 03:27PM |
Re: Precision Piezo Z-probe Now available. September 20, 2019 04:50PM |
Re: Precision Piezo Z-probe Now available. September 20, 2019 10:55PM |
jens53
Please note that no matter how heavy the rails and how light the head, there will be deflection. Conversely, any touching of the head to the build platform will produce deflection. The best you can do is have consistent deflection which you can compensate for.
Re: Precision Piezo Z-probe Now available. September 24, 2019 09:58AM |
MKSA
jens53
Indeed with such 8mm rods more than 310mm in length (bed) and a 1.1Kg mass, the plotted bed map will have a nice shape far from flat even if the bed is a perfectly flat 8mm thick MIC plate !
Deflections are in 0.1mm;
Re: Precision Piezo Z-probe Now available. September 24, 2019 11:03AM |
ryan99alero
There were area's that would spike up and move around with multiple probe attempts. I have been tweaking and getting those reduced. I finally finished designing new fan guides that will also hold the BL Touch so I can compare probing system's map results.
Re: Precision Piezo Z-probe Now available. September 24, 2019 01:42PM |
Re: Precision Piezo Z-probe Now available. September 24, 2019 02:52PM |
Re: Precision Piezo Z-probe Now available. November 10, 2019 04:53AM |
Re: Precision Piezo Z-probe Now available. November 10, 2019 08:19AM |
Re: Precision Piezo Z-probe Now available. November 10, 2019 02:31PM |
Re: Precision Piezo Z-probe Now available. November 11, 2019 03:05AM |
whosrdaddy
Underbed sensing is really only suitable for stationary beds (think Delta's). You can always put a piezo between the carriage and hotend assembly.
Works flawlessly on my P3 steel :
