Re: Precision Piezo Z-probe Now available. December 12, 2019 07:10AM |
Re: Precision Piezo Z-probe Now available. December 12, 2019 07:49AM |
Admin Registered: 11 years ago Posts: 3,096 |
Moriquendi
@Ohmarinus,
That's not actually a piezo sensor at all, it's an FSR, a force sensitive resistor, they are much more delicate than piezo disks and not as accurate.
Idris
Re: Precision Piezo Z-probe Now available. December 12, 2019 11:47AM |
Re: Precision Piezo Z-probe Now available. December 13, 2019 05:07AM |
Re: Precision Piezo Z-probe Now available. December 13, 2019 11:45AM |
Re: Precision Piezo Z-probe Now available. December 14, 2019 12:10PM |
Re: Precision Piezo Z-probe Now available. December 23, 2019 01:59AM |
Re: Precision Piezo Z-probe Now available. December 23, 2019 02:13AM |
Re: Precision Piezo Z-probe Now available. December 23, 2019 10:04AM |
Re: Precision Piezo Z-probe Now available. December 23, 2019 10:12AM |
Re: Precision Piezo Z-probe Now available. December 24, 2019 11:18AM |
Re: Precision Piezo Z-probe Now available. December 26, 2019 05:38AM |
Re: Precision Piezo Z-probe Now available. December 27, 2019 05:01AM |
Re: Precision Piezo Z-probe Now available. December 27, 2019 06:26AM |
leadinglights
I have recently been doing some considerable research on underbed piezos to try to find out why some people find thme to be the best and others find them unusable. Although I have used these on all of my own printers I had not discovered some of the problems that they can have. In brief, having piezos mounted too far in from the edge of the bed can give bad results and 27mm are better than 20mm piezos. There are other things worth noting but I will include them when I report what I have found.
In answer to your specific questions, the piezos respond to pressure rather than vibration. There is a limit to how much pressure piezos before they become less sensitive, Under direct pressure (not bending) the 27mm piezos work well with up to 1.6kg per piezo while the 20mm with up to about 0.75kg - I am less sure in the bending case.
Edit: The contact force and speed for a good piezo setup is so low that it won't mark any surface. I use a Z speed of 2mm per second and get contact pressure of less than 25 grams in the worst case - less than 10 grams is normal.
I am away from base at the moment and am also using a Chromebook on my lap while surrounded by overexcitable children and relatives but hope to put the results of my research in this forum by early next week.
Mike
Re: Precision Piezo Z-probe Now available. December 27, 2019 06:56AM |
Re: Precision Piezo Z-probe Now available. December 29, 2019 02:18PM |
Re: Precision Piezo Z-probe Now available. December 29, 2019 02:29PM |
Dancer
I have two deltas with Piezos as under bed sensors. Work perfectly since more than two years
[reprap.org]
Re: Precision Piezo Z-probe Now available. December 29, 2019 02:39PM |
Re: Precision Piezo Z-probe Now available. December 29, 2019 04:21PM |
Dancer
Yes.
Some pictures:
[reprap.org]
I call the lower part "cups". They are mounted, so that the top parts (inserts) are not completely loose but little bit rubbing on one of the inside wall of the cups.
Config is still the same as on the pictures taken in August 2017 - and many rolls of filament have gone down on this printer
Re: Precision Piezo Z-probe Now available. January 02, 2020 04:40PM |
Re: Precision Piezo Z-probe Now available. January 11, 2020 11:02AM |
Re: Precision Piezo Z-probe Now available. January 11, 2020 12:01PM |
Re: Precision Piezo Z-probe Now available. January 11, 2020 12:26PM |
Re: Precision Piezo Z-probe Now available. January 11, 2020 01:37PM |
leadinglights
As heard many times over the years, and just as WRONG now as then. The best sensor depends on the use: Multiple interchangeable heads, ultra-thin layers etc.. Saying there is only one best way is like saying there is only one king of road vehicle (well O.K., only the 1938 SS Jaguar need apply)
edit: That was supposed to be "some kind of road vehicle" but I will leave king as it is.
Mike
Re: Precision Piezo Z-probe Now available. January 11, 2020 02:47PM |
Re: Precision Piezo Z-probe Now available. January 11, 2020 04:04PM |
Re: Precision Piezo Z-probe Now available. January 11, 2020 04:41PM |
Dancer
My 3rd 3D-Printer.
A Prusa Mendel i2 with Under-bed-piezos in the "cups" shown in the middle of this page: Standard Deviation: 0.001034
Re: Precision Piezo Z-probe Now available. January 11, 2020 04:52PM |
Re: Precision Piezo Z-probe Now available. January 11, 2020 06:26PM |
Re: Precision Piezo Z-probe Now available. January 12, 2020 05:05AM |
