Re: Precision Piezo Z-probe Now available. January 12, 2020 08:19AM |
Dancer
I do not know.
But there are 4 Piezos... (Standard 220 x 220 Heatbed, 4 Holes on the Edges)
Most important is to wait 1 second before each probing, because the piezos trigger from the Y-movement.
Pictures of the Printer to come (SD-Reader not working in PC...)
Re: Precision Piezo Z-probe Now available. January 12, 2020 08:48AM |
Re: Precision Piezo Z-probe Now available. January 12, 2020 05:21PM |
Re: Precision Piezo Z-probe Now available. January 13, 2020 04:28AM |
Dancer
Sorry MKSA. I think that you are just repeating what you heared from others instead of thinking yourself.
Over and Out.
Re: Precision Piezo Z-probe Now available. January 13, 2020 07:41AM |
Admin Registered: 11 years ago Posts: 3,096 |
MKSA
Dancer
Over and Out.
Can an admin prompt this guy to remove this personal attack ?
Of course, the rest of the post can stay as it is so entertaining.
Re: Precision Piezo Z-probe Now available. January 17, 2020 05:40PM |
Re: Precision Piezo Z-probe Now available. January 23, 2020 06:19PM |
Re: Precision Piezo Z-probe Now available. January 28, 2020 07:19AM |
Re: Precision Piezo Z-probe Now available. January 28, 2020 10:55AM |
Re: Precision Piezo Z-probe Now available. January 29, 2020 03:20AM |
CaboGuataca
Hi everyone,
I'm thinking to upgrade my Rostock Max using one of the piezo probes DjDemonD and company provides, but I'm having doubts about the best way to do so. Let me briefly explain my setup:
My Rostock MAX v2 glass bed got broken a few years ago and since then I replaced it with a cheap glass. Since then I haven't been able to print to the full width or consistently for that matter. Lately I'm thinking of purchasing a spring steel bed Energetic beds on aliexpress and place the magnetic sticker directly into the heated bed so as to obtain better thermal conductivity and hopefully a flatter surface. My fear with this is that probing might damage the heated bed if something goes wrong with the probing like a faulty piezo, too little sensitivity in certain probe points or anything else. I hope I can hard code a safety min Z to prevent that (I'm trying Klipper at the moment). I also rather install 3 piezos on the bed rather than using the Orion because it's kind of annoying to rewire a Rostock and also because I want to keep the hotend as fixed as possible (I'm using a genuine E3D Volcano so the installation of the Orion should actually be pretty straightforward). However, since the Rostock has a large bed I wonder if it would be more precise to use the Orion instead of a bed setup. I'm also wondering why I mostly find FSR setups but little on piezos for the Rostock (except CodeBusters proposal the other day). Is it because of practical or popular reasons?
Re: Precision Piezo Z-probe Now available. January 29, 2020 10:52AM |
CodeBuster
Precision of the least squares calibration at the furthest extents of the bed relies on two things according to dc42 :
1. Including probe points near the edge of the bed
2. Allowing 7 factor (delta arm length is adjusted) calibration
I get .05mm deviation across the bed. That's pretty friggin good, considering Duet/SE300 hot end users get .03mm deviation as a matter of course.
Re: Precision Piezo Z-probe Now available. January 30, 2020 03:44AM |
Re: Precision Piezo Z-probe Now available. February 03, 2020 05:10AM |
Re: Precision Piezo Z-probe Now available. February 16, 2020 01:04PM |
han45
Hi guys, I'm using the Piezo Orion on a E3D V6 setup with a bowden extruder and it works really well.
Now I ordered an E3D Hemera and I want to use the Orion with that. Is there any chance to make it work? Maybe use the Orion vertically between the Hemera and it's mounting plate to detect the touch on the build plate?
Any pointers on what I can do are welcomed.
Re: Precision Piezo Z-probe Now available. February 24, 2020 07:46AM |
Re: Precision Piezo Z-probe Now available. March 01, 2020 01:02PM |
Re: Precision Piezo Z-probe Now available. March 02, 2020 08:52AM |
Re: Precision Piezo Z-probe Now available. March 02, 2020 01:02PM |
Re: Precision Piezo Z-probe Now available. March 09, 2020 05:40PM |
Re: Precision Piezo Z-probe Now available. March 10, 2020 04:53AM |
Re: Precision Piezo Z-probe Now available. March 18, 2020 06:52AM |
Re: Precision Piezo Z-probe Now available. March 18, 2020 10:02AM |
Re: Precision Piezo Z-probe Now available. March 18, 2020 12:18PM |
Re: Precision Piezo Z-probe Now available. March 18, 2020 04:40PM |
Re: Precision Piezo Z-probe Now available. March 19, 2020 06:48AM |
Re: Precision Piezo Z-probe Now available. March 19, 2020 07:45AM |
Re: Precision Piezo Z-probe Now available. March 24, 2020 08:25AM |
Re: Precision Piezo Z-probe Now available. March 24, 2020 09:57AM |
Re: Precision Piezo Z-probe Now available. April 03, 2020 01:55PM |
Re: Precision Piezo Z-probe Now available. April 03, 2020 02:13PM |
