Re: Precision Piezo Z-probe Now available. April 03, 2020 02:24PM |
Moriquendi
I've just uploaded a microswiss clamp to thingiverse here.
I don't have a microswiss hotend to test it myself but it's a modification of the CR10 clamp that is known to work.
Idris
Re: Precision Piezo Z-probe Now available. April 04, 2020 03:55AM |
Water cooled chimera April 05, 2020 05:07AM |
Re: Precision Piezo Z-probe Now available. April 05, 2020 06:06PM |
Re: Precision Piezo Z-probe Now available. April 06, 2020 08:08AM |
Re: Precision Piezo Z-probe Now available. April 06, 2020 08:44AM |
Re: Precision Piezo Z-probe Now available. April 13, 2020 06:07PM |
Re: Precision Piezo Z-probe Now available. April 14, 2020 10:58AM |
Re: Precision Piezo Z-probe Now available. April 14, 2020 02:02PM |
Re: Precision Piezo Z-probe Now available. April 15, 2020 09:27AM |
M558 H25 T9000 A10 P3 I1 R0.4 S0.02 F500 G31 X0 Y0 Z-0.15 P100
G28 X G1 Z25 F8000 G30 S-1 ...the above two lines *100 G28 X
Re: Precision Piezo Z-probe Now available. April 15, 2020 12:57PM |
Re: Precision Piezo Z-probe Now available. April 15, 2020 02:04PM |
M558 H5 T9000 A10 P8 I1 R0.4 S0.02 F120 ; M558 dive Height, Travel speed, probing Attempts, Probe type, Remain, dive speed F G31 X0 Y0 Z-0.15 P100 ; Set Z probe trigger value, offset and trigger height Z-0.012 / Z-0.45
G28 X G1 Z5 F3000 G30 S-1 ... above two lines x100 G28 X
G28 X G1 Z5 F3000 G30 S-1 G1 Z40 F6000 G1 Z5 F6000 ... above three lines x100 G28 X
Re: Precision Piezo Z-probe Now available. April 15, 2020 04:01PM |
Re: Precision Piezo Z-probe Now available. April 16, 2020 03:48AM |
Re: Precision Piezo Z-probe Now available. April 17, 2020 12:43PM |
Re: Precision Piezo Z-probe Now available. April 18, 2020 12:27PM |
Re: Precision Piezo Z-probe Now available. April 19, 2020 12:30AM |
Re: Precision Piezo Z-probe Now available. April 23, 2020 09:40PM |
CodeBuster
I've been having a problem with my mount setup recently. It's a hotend probe on a delta.
I noticed the bolts had loosened over time, because I had not fully engaged the ring of the nylock nuts with the the threads.
I switched out the 60mm bolts for 65mm bolts. Now I have two probe points at the front of the Z axis and slightly to the -X direction of that won't ever probe any less than .2mm higher than the rest of the points.
I've tried every combination of rebuilding the thing. Wobbly effector, tight effector, lots of preload on the piezo, almost no preload.
None of it has made any difference. The piezo still triggers as expected .
What do you guys do when your Orion has binding? It's a similar setup, but mine is a 3 point instead of 4 point mounting solution.
Re: Precision Piezo Z-probe Now available. April 26, 2020 08:58AM |
Re: Precision Piezo Z-probe Now available. April 27, 2020 06:23AM |
Re: Precision Piezo Z-probe Now available. April 27, 2020 10:32AM |
Re: Precision Piezo Z-probe Now available. April 30, 2020 04:20PM |
Re: Precision Piezo Z-probe Now available. May 07, 2020 05:06AM |
Moriquendi
What I'm saying is that I think you have too much weight on the Andromeda sensors.
Why do you need to dive 400mm? Does your bed not rest at z=0?
Idris
Re: Precision Piezo Z-probe Now available. May 07, 2020 05:13AM |
ValSimDim
Hi guys, I'm an old happy piezo user, currently using two Orion modules on my 2 custom CoreXY printers with Duet Maestro boards. I remember someone in the past shared a macro for duet boards for repeatability, something like probing the bed at one point 10 times and giving the results. I'll appreciate if you point me where I can find it.
Re: Precision Piezo Z-probe Now available. May 07, 2020 05:57AM |
Re: Precision Piezo Z-probe Now available. May 11, 2020 06:22AM |
Re: Precision Piezo Z-probe Now available. May 22, 2020 11:58PM |
Re: Precision Piezo Z-probe Now available. May 23, 2020 12:08AM |
Re: Precision Piezo Z-probe Now available. May 23, 2020 04:26PM |
Re: Precision Piezo Z-probe Now available. May 24, 2020 12:58AM |
