Re: Precision Piezo Z-probe Now available. July 05, 2020 05:26PM |
Re: Precision Piezo Z-probe Now available. July 15, 2020 09:14AM |
Re: Precision Piezo Z-probe Now available. July 15, 2020 11:12AM |
Re: Precision Piezo Z-probe Now available. July 16, 2020 10:49AM |
Re: Precision Piezo Z-probe Now available. July 16, 2020 11:46AM |
Re: Precision Piezo Z-probe Now available. July 18, 2020 05:00PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Precision Piezo Z-probe Now available. July 18, 2020 07:03PM |
Re: Precision Piezo Z-probe Now available. July 19, 2020 06:31AM |
Re: Precision Piezo Z-probe Now available. July 19, 2020 10:32AM |
Re: Precision Piezo Z-probe Now available. July 19, 2020 12:19PM |
leadinglights
5mm should be fine. If the contact point is too small then there is a risk of damaging the PZT ceramic while if it is too large much of the bending would be in theo uoter part where there is no piezoelectric material.
Your design should work well but try not to let the perimeter of the bed snag on the body part of your supports - as long as there is a little clearance around the edge then a quick tap with your knuckles or the blunt end of a screwdriver will stop it snagging.
Mike
Re: Precision Piezo Z-probe Now available. July 20, 2020 03:30AM |
Re: Precision Piezo Z-probe Now available. July 20, 2020 02:22PM |
Re: Precision Piezo Z-probe Now available. July 21, 2020 01:45PM |
Re: Precision Piezo Z-probe Now available. July 22, 2020 10:51AM |
Re: Precision Piezo Z-probe Now available. July 23, 2020 06:02AM |
Moriquendi
The digital output probably needs tuning using VR2.
Unfortunately I don't have much current experience of Marlin so I can't help you with that.
Idris
Re: Precision Piezo Z-probe Now available. September 24, 2020 09:25PM |
Re: Precision Piezo Z-probe Now available. September 25, 2020 04:47AM |
Re: Precision Piezo Z-probe Now available. September 29, 2020 10:48AM |
Re: Precision Piezo Z-probe Now available. September 29, 2020 02:19PM |
Re: Precision Piezo Z-probe Now available. September 29, 2020 04:37PM |
Re: Precision Piezo Z-probe Now available. October 20, 2020 04:31PM |
Re: Precision Piezo Z-probe Now available. October 21, 2020 03:15PM |
Re: Precision Piezo Z-probe Now available. October 21, 2020 07:40PM |
Re: Precision Piezo Z-probe Now available. October 21, 2020 11:58PM |
Re: Precision Piezo Z-probe Now available. October 22, 2020 12:54AM |
Re: Precision Piezo Z-probe Now available. October 22, 2020 08:33AM |
Re: Precision Piezo Z-probe Now available. October 22, 2020 11:52AM |
Ohmarinus
Printed one example, and it looks like it could actually work. I don't even think that the rubber is needed between the left and right bolts. If I 'bend' the compression arm by using a spacer between the bed and the arm at the bolt points, this will cause the sides of the compression bar to curve down and logically the center of the bar will be the highest point, logically causing it to be the only point the bed then rests on. The bolts will only keep the bed in place and apply a bit of downforce.
Finished module; the top bar is pushing on the piezo disc with a 5mm round point:
[attachment 116225 IMG_POCO_F1_20200719_121733-01.jpeg]
Top view, notice the hole for the wires:
[attachment 116226 IMG_POCO_F1_20200719_121758-01.jpeg]
Here you see the bottom of the disc and how it is supported around it's rim:
[attachment 116227 IMG_POCO_F1_20200719_121744-01.jpeg]
I wonder if anyone has ever made something similar.
When I print the other three parts, I will show it mounted to the heated bed.
Meanwhile, concerning the electronics... Does anyone have an idea how to best connect the wires? And is it critical all piezo's have the same total wire length? I have bad experiences with crimping such thin wires and the wires are only 40mm long so they need to be extended because in this setup the three discs cannot be connected to the PCB with such short wires.
Furthermore, is a 5mm surface point enough to depress the piezo? Do I have to visually deform the piezo under stress to generate a signal, or is simply pushing on it already enough? I can re-design the pressure bar to have a smaller point, resulting in a lower surface area of contact, and a higher pressure in the center of the piezo.
Edit;
One more example showing how the bed is mainly touching the piezo:
(in this configuration the bolts are not tied down completely so the bed is really only resting purely on the piezo)
[attachment 116228 IMG_POCO_F1_20200719_124302-01_d.jpg]
Re: Precision Piezo Z-probe Now available. October 22, 2020 02:57PM |
Re: Precision Piezo Z-probe Now available. October 31, 2020 06:07PM |
Re: Precision Piezo Z-probe Now available. November 02, 2020 01:44PM |
