leveling wheel
May 30, 2017 07:34PM
I just printed a set of leveling wheels to make bed leveling easier. I seems the 3 mm nuts don't stay in the opening made for them. How have you gotten them to stay?
PLA slurry added with a art brush?
Re: leveling wheel
May 31, 2017 02:11AM
You can use any glue you like, or change the design by scaling it down in your slicer until it fits tight.
Re: leveling wheel
May 31, 2017 02:37AM
Alternatively, you can make the model so that the nuts are enclosed.
Print until the layers are high enough to cover the nuts, pause, insert nuts, continue printing.
Captive nuts are so much more secure.
Lykle
Re: leveling wheel
May 31, 2017 02:56AM
Why doesn't the bolt or threaded rod hold the nut in place?
Re: leveling wheel
June 02, 2017 05:17PM
The nuts don't *need* to stay in the plastic, just place them whichever way around they won't fall off. They only have to be tight enough to grip the nut. My personal option is heat press insert the nut. Make the nut hole slightly too small, heat up nut and drop in place. Not too hot, just hot enough to slightly melt plastic. Can also use a soldering iron to heat nuts, but a lighter will do.
Re: leveling wheel
June 03, 2017 10:25AM
or redesign the part for brass inserts
Check my rubbish blog for my prusa i3
up and running
[3dimetech.blogspot.co.uk]
Re: leveling wheel
June 04, 2017 05:00AM
If you have brass inserts that is the best solution, yes.
Also my preferred solution.
Re: leveling wheel
June 17, 2017 11:47AM
This might help ... [www.youtube.com]
Re: leveling wheel
June 18, 2017 03:35PM
That's an odd way of using nuts. The nuts are free to move in or out. They only rely on the friction between the nut and the pla to keep them in place. How hard can it be to design a proper seat for the nuts?
Re: leveling wheel
June 20, 2017 01:42PM
Not hard.
I do it in the Dual Nimble. Little nubs that allow you to click in a nut and the nut will stay in there.
Even when positioned on the Chimera they do not fall out and still have enough room to "settle" and be pulled tight.
Is a standard component in my design library now.
Lykle
________________________________________________
Co-creator of the Zesty Nimble, worlds lightest Direct Drive extruder.
[zesty.tech]
